I'm following the design of a circuit requiring a power supply to provide something the author calls virtual ground, \$V_{gnd}\$. The circuit look like this:
However, I'm using KiCad for the design and out of all the available power supply symbols, I can't find any that seem appropriate. I'm already using both the earth ground and common/signal ground symbols for something else. In fact, from that schematic, I can't even tell if that virtual voltage is negative or positive.
I have also looked at these relevant questions:
Apart from just labeling the network as the author does...
Q: What would be a more appropriate symbol to replace \$V_{gnd}\$?
PS. Is it just me, or is this diagram extremely sloppy? It seem very strange that some power networks terminate in mid air, while others are just labelled in-circuit without any termination. I can't imagine this is standard design practice.
UPDATE:
  • The battery is a 3.7V LiPo.
  • The U1 pins are "1" for + and "2" for -.
  • The pins for the AD8607 as shown above are wrong and should be: enter image description here
    \$\begingroup\$ The naming of the net is not the most serious problem with that circuit. It's way over the 2nF recommended capacitive loading and will likely oscillate and get hot. \$\endgroup\$ Apr 15, 2019 at 16:30
  • \$\begingroup\$ You don't really 'provide' a virtual ground - it just happens as a consequence of the configuration. \$\endgroup\$
    – Chu
    Apr 15, 2019 at 16:33
  • \$\begingroup\$ @SpehroPefhany Oh!? Thanks for that pointer. Clearly I need to find another way to provide whatever that voltage is. Any possibility you could clarify or link me to how to better understand the problem you mentioned? \$\endgroup\$
    – not2qubit
    Apr 15, 2019 at 16:36
  • \$\begingroup\$ Usually, capacitors are not connected directly to op-amp output. They don't like it. The circuit looks like it's made by a beginner, or for beginners, to have something to work on a concept called virtual ground. In this case, virtual ground is just VDD/2, half of the supply voltage, buffered by an op-amp. \$\endgroup\$
    – Justme
    Apr 15, 2019 at 16:41
    \$\begingroup\$ Check out the datasheet. This op-amp is capable of 2nF loading without oscillation, which is actually unusually good (especially for a low-power op-amp), and they promote it as a feature. So if C2/C102 were reduced to 1nF it might be okay. There are dedicated rail splitter chips that replace that whole mess. Eg. TLE2426 or you can add compensation if you really want to use an op-amp. \$\endgroup\$ Apr 15, 2019 at 17:34
6
I wouldn't use the "earth" symbol unless I meant mains earth or Earth.
There are various ground symbols available.
Figure 1. From Ground, earth and chassis explained (by me).
In your case I would probably use the hollow ground symbol for the real ground and the solid ground symbol for the virtual ground.
Figure 2. Different ground symbols for primary ground and virtual ground.
Notes:
  • R1 and 2 provide a VCC/2 reference.
  • C1 stabilises the reference voltage and keeps it constant during fluctuations in VCC.
  • U1 provides the virtual ground.
  • C2 is the supply decoupling capacitor for the op-amp.
From the comments:
The opamp is just a voltage follower? Why call Vcc/2 virtual ground?
Virtual ground appears to have several meanings. In the inverting amplifier op-amp configuration it refers to the inverting input as being very close to ground potential due to the high gain and negative feedback. In this case of Figure 2, below, and the OP's question it is a ground or reference for the audio signals and they alternate above and below that reference voltage and are equal to that reference voltage when the audio is quiescent.
The term seems to have high-level approval. See TI's datasheet for TLE2426, The "Rail Splitter precision virtual ground" device.
Figure 3. The Belton-Brick uses a virtual ground reference, VB, for biasing all all the op-amps in the audio signal chain to half-supply to allow for alternating audio voltages. (Double-click for high resolution.) Source: Hot Bottles.
  • \$\begingroup\$ The opamp is just a voltage follower? Why call Vcc/2 virtual ground? \$\endgroup\$
    – Huisman
    Apr 15, 2019 at 19:14
  • \$\begingroup\$ See the update. Does that help? \$\endgroup\$
    – Transistor
    Apr 15, 2019 at 19:33
  • \$\begingroup\$ Thank you. I just found out myself, still +1 for adding/explaining. \$\endgroup\$
    – Huisman
    Apr 15, 2019 at 19:37
Although I chose to accept Transistor's answer, liking his clear and detailed explanation, I still can't get over the queasy feeling about using a ground related symbol for the virtual ground reference voltage.
So perhaps this question and discussion is more subjective and psychological in nature, than I first thought. In this regard, I think using a downward pointing ground symbol is misleading. As was already pointed out, the driver circuit is just a voltage divider buffered by an OpAmp, whose output is still a positive voltage compared to the battery ground. Therefore it just seem more natural to have something pointed up, instead of down, since nothing is really getting sinked here, even if it is at a lower voltage than \$V_{dd}\$.
One symbol that may provide a better pictorial "feeling" may be what (in KiCad) is referred to as digital ground, whose symbol is:
But instead of having it downward in the driver circuit, we have it up like this:
Then, when we actually use it in the circuit, we have it down.
I would love to hear what the community thinks about this, especially if I am violating some design standards by doing it this way.
