I am trying to write verilog code to do sequence detector the the state diagram below. Input is a 2-bit signals and there're 3 state variables as in the image. The goal is to detect the sequence (01)-(11). When this sequence is detected the output (1 bit signal) is 1.
I tried the code below but somehow it doesn't work expected. In my first test, if I set up reset is zero all the time then the output signal some part is correct and some part isn't.
However, when I set a reset at the rising edge of clock, the output is always zero and two registers state and next_state is always unknown. Could anyone tell me what is wrong with it and how to fix it?
module SeqDect(rst,clk,ip,op);
output reg op;
input clk, rst;
  input [1:0] ip;
reg [1:0] state;
reg [1:0] next_state;
  parameter [1:0] s0=2'b00;
  parameter [1:0] s1=2'b01;
  parameter [1:0] s2=2'b10;
always @(posedge clk, posedge rst)
begin
if (rst)
  state=s0;
    else
  state=next_state;
end
always @(state, next_state)
begin
case(state)
s0:
if (ip==2'b01)
  begin
    next_state=s1;
    op=1'b0;
  end
  else
  begin
    next_state=s0;
    op=1'b0;
  end
    s1:
  if (ip==2'b11)
  begin
    next_state=s2;
    op=1'b1;
  end
  else if (ip==2'b01)
  begin
    next_state=s1;
    op=1'b0;
  end
  else
  begin
    next_state=s0;
    op=1'b0;
  end
    s2:
  if (ip==2'b11)
  begin
    next_state=s2;
    op=1'b1;
  end
  else if (ip==2'b01)
  begin
    next_state=s1;
    op=1'b0;
  end
  else
  begin
    next_state=s0;
    op=1'b0;
  end
    default:
  begin
          next_state=s0;
          op=1'b0;
  end
    endcase
end
endmodule
    \$\begingroup\$ You should be using non-blocking assignments to update state. Beyond that, if you have a working simulation you can examine internal signals to see where things go wrong. That's much better than trying to debug code by inspection. \$\endgroup\$ – Elliot Alderson Apr 15 '19 at 19:41
  • \$\begingroup\$ @ElliotAlderson I fixed it but the result is same. It doesn't change anything. The problem is still that state and next_state variable are always unknown as in the images. \$\endgroup\$ – anhnha Apr 16 '19 at 6:36
your first always block is a sequential circuit so, never forget to use non-blocking assignment.
your second always block is a combinational circuit and you must declare all the input signals in the sensitivity list. or you can set always @(*)
(Line 16,18,21 changed)
   /*io and internal wires*/
    begin
    if (rst)
      state<=s0;
        else
      state<=next_state;
    end
    always @(state, ip)
    begin
    case(state)
    /*cases*/
        endcase
    end
    endmodule
testbench module:
module tb();
reg rst;
reg clk;
reg [1:0] ip;
wire op;
SeqDect uut(rst,clk,ip,op);
always #20 clk =~clk;
initial begin
clk=0;
rst=1;
#100
rst=0;
#100
ip = 2'b00;
#100
ip = 2'b01;
#100
ip = 2'b11;
#100
$stop;
end
endmodule
modelsim simulation results:
