I want to make induction heater. So I want to make oscillator for this. I want to make oscillator with transistor, inductor, resistor, diode and capacitors but not IC, relay switch, op amps etc. Which oscillator should I make?
The required frequency of oscillator is from 15-50 kHz.
  • \$\begingroup\$ So you want a 10,000 watt oscillator? \$\endgroup\$ – analogsystemsrf Apr 17 '19 at 13:04
  • \$\begingroup\$ @analogsystemsrf i want to make oscillator for induction heater to melt aluminum cans \$\endgroup\$ – Maha Yuddha Apr 17 '19 at 13:39
There are a lot of options, but here are a couple of examples:
The first (which is really a pulse generator), from Unijunction Transistor, shows that there are three outputs that can be taken: VC1 (sawtooth), VB1 (positive pulse) and VB2 (negative pulse):
Unijunction Transistor oscillator
$$T = \frac{1}{f}= R_3Cln\left(\frac{1}{1-\eta}\right)$$
For a 2N2646 Unijunction Transistor, the intrinsic stand-off ratio η as 0.65, as stated in the data sheet.
An example of an astable multivibrator using emitter-coupled oscillators can be found in Electronics Tutorials - Astable Multivibrator
Emitter-coupled oscillator
The periodic time is given by:
$$T = t_1 + t_2$$
$$t_1 = 0.69R_3C_1$$ $$t_2 = 0.69R_2C_2$$
If
$$R_2 = R_3$$
and
$$C_1 = C_2$$
then the frequency of the resultant symmetric waveform is given by:
$$f= \frac{1}{T} = \frac{1}{1.38RC}$$
I, myself, looked into the subject of oscillators recently, and I found some which used only discrete components and came up with a number of options, which I listed in my blog, Swingers.
  • \$\begingroup\$ Can multivibrator provide the 15-50 khz frequency? \$\endgroup\$ – Maha Yuddha Apr 17 '19 at 6:55
  • \$\begingroup\$ Yes, if you chose appropriate values for C1 and R2. I'll update my answer with some equations shortly \$\endgroup\$ – Greenonline Apr 17 '19 at 7:59
  • \$\begingroup\$ thank you for your answer \$\endgroup\$ – Maha Yuddha Apr 18 '19 at 16:14
