This is the component I'm trying to remove: BU48xx voltage detector VSOF package (attached pic)enter image description here
    \$\begingroup\$ Hot air tool of course. This is surely a duplicate of several existing questions. \$\endgroup\$ Commented Apr 17, 2019 at 6:51
  • \$\begingroup\$ If you have no hot air, 2 soldering irons might also work, the component might not survive though. Hot air and experience how to use that are the best option though. \$\endgroup\$ Commented Apr 17, 2019 at 7:01
  • \$\begingroup\$ Another "trick" is using a very big solder iron tip and putting lots of solder on it. Then you can use that "solder drop" to heat all pins and the component simultaneously. Sometimes it will just come off, but maybe you have to push it slightly to the side. However, this is likely to damage the component because of excessive heating. \$\endgroup\$
    – Rev
    Commented Apr 17, 2019 at 7:15
  • \$\begingroup\$ You could use a tip designed for the purpose. paceworldwide.com/products/tips-and-nozzles/soldering-iron-tips/… \$\endgroup\$ Commented Apr 17, 2019 at 7:55
  • \$\begingroup\$ You do it as described here. That gives a step by step description of removing and replacing an 8 pin SMD part. It'll work just as well for your problem, but heat the side with 4 pins first, and then heat the side with two pins and pull the part out. The four pin side first because the larger volume of solder on that side will stay hot (and liquid) longer. \$\endgroup\$
    – JRE
    Commented Apr 17, 2019 at 9:22
