When I select multiple designators and when I select "properties" - only one designator changes. I have same problem with setting other parameters on multiple objects.
How can I change all existing designator font sizes on PCB in Altium?
    \$\begingroup\$ Do you use 'find similar'? That certainly works for many parameters. \$\endgroup\$ Apr 17, 2019 at 8:56
Right click on one designator.
Select "Find Similar Objects".
Set "Object Kind : Text" to "same" Set "String Type : Designator to "same"
Then "apply".
All designators are now selected.
Use the properties panel to edit the text size of all selected texts.
    \$\begingroup\$ Ooops I forgot to mark this as an answer long time ago. \$\endgroup\$
    – Kamil
    Jan 16, 2022 at 21:58
