Am totally new to electronics and the datasheet is very confusing to me, so can anyone please guide me through the specification of the accelerometer? So that i can have a better understanding on the accelerometer and to be able to convert the accelerometer data into G.
This is the datasheet for the ADXL345 digital accelerometer [1]: https://www.analog.com/media/en/technical-documentation/data-sheets/ADXL345.pdf
import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# ADXL345 address, 0x53(83)
# Select bandwidth rate register, 0x2C(44)
# 0x0A(10) Normal mode, Output data rate = 100 Hz
bus.write_byte_data(0x53, 0x2C, 0x0A)
# Select power control register, 0x2D(45)
# 0x08(08) Auto Sleep disable
bus.write_byte_data(0x53, 0x2D, 0x08)
# Select data format register, 0x31(49)
# 0x08(08) Self test disabled, 4-wire interface
# Full resolution, Range = +/-2g
bus.write_byte_data(0x53, 0x31, 0x08)
time.sleep(0.5)
# Read data back from 0x32(50), 2 bytes
# X-Axis LSB, X-Axis MSB
data0 = bus.read_byte_data(0x53, 0x32)
data1 = bus.read_byte_data(0x53, 0x33)
# Convert the data to 10-bits
xAccl = ((data1 & 0x03) * 256) + data0
if xAccl > 511 :
xAccl -= 1024
# Read data back from 0x34(52), 2 bytes
# Y-Axis LSB, Y-Axis MSB
data0 = bus.read_byte_data(0x53, 0x34)
data1 = bus.read_byte_data(0x53, 0x35)
yAccl = ((data1 & 0x03) * 256) + data0
if yAccl > 511 :
yAccl -= 1024
# Read data back from 0x36(54), 2 bytes
# Z-Axis LSB, Z-Axis MSB
data0 = bus.read_byte_data(0x53, 0x36)
data1 = bus.read_byte_data(0x53, 0x37)
zAccl = ((data1 & 0x03) * 256) + data0
if zAccl > 511 :
zAccl -= 1024
# Output data to screen
print ("Acceleration in X-Axis : %d" %xAccl)
print ("Acceleration in Y-Axis : %d" %yAccl)
print ("Acceleration in Z-Axis : %d" %zAccl)
These are the code.
