6
I have a signal that is roughly 0.2V + noise fluctuations of order 0.1-2 mV. Ideally I want to amplify this signal such that the mV fluctuations become about 1V. In other words I want to amplify the signal by about 1000x.
However, if I flat out amplify the signal, the total signal becomes 200V + 1V fluctuations, which I can't reasonably read on some bench top DAQ (0-10V range).
Is there some combination of circuit elements that can take my input 0.2V + 1mV signal and spit out only the amplified fluctuations (i.e. 0V + 1V fluctuations)?
I should say that these fluctuations are controlled by me physically squeezing a pressure gauge, so they aren't necessarily high frequency. Basically the signal rises to 0.202V when I squeeze, and 0.200V when I let go. I want to see that excess 0.002V blown up to 1V, but I may be squeezing and letting go slowly in general.
  • \$\begingroup\$ Are you interested in the signal? Or the noise? I can't tell from the writing. I'd normally assume that you don't want the signal part. But I'd rather not assume. Instead, just ask. \$\endgroup\$ – jonk Apr 17 at 21:48
12
Capacitors block DC and pass AC.
You can use a series capacitor into an opamp with whatever gain you need.
Even better might be a simple RC high-pass filter...One capacitor (series) and one resistor (to ground) in front of your amplifier.
Like this:
R2 and R3 set your gain. C1 and R1 set your low frequency cut-off. The formula you use to find the cutoff is:
$$F\text{(Hz)} = \frac{1}{2 \pi R C}$$
  • \$\begingroup\$ Thank you for your answer! If you see my edit: will the capacitor block out the fluctuations if they aren't very fast (maybe a quick squeeze/release every 2 seconds)? i.e. a voltage difference when I squeeze a pressure gauge (squeezing vs not squeezing is only a ~1mV signal added to the 0.2V DC) \$\endgroup\$ – Marty Apr 17 at 21:52
    \$\begingroup\$ It's called "MathJax". I've added your formula to your answer to show you how it's done. You can learn more by clicking on the help icon in the editor, select "Advanced Help" and scroll down to the section labeled "LaTeX", which also has a link to MathJax specifically. There's also this post on meta, which provides links to a number of quick references and other resources. \$\endgroup\$ – Dave Tweed Apr 17 at 22:03
    \$\begingroup\$ So if I wanted a gain of 1000 and a cutoff of 1 Hz, the following values might work? C1=100 uF, R1=1.5k ohm, R2=100k ohm, R3=100 ohm \$\endgroup\$ – Marty Apr 17 at 22:04
    \$\begingroup\$ @Marty in most circumstances, I would prefer to increase resistance instead of capacitance. A larger resistor value is the same price and physical size as a small resistance, but a large capacitor is much larger physically and more expensive than a small one. \$\endgroup\$ – user60561 Apr 18 at 4:05
    \$\begingroup\$ Note that a filter with a long time constant can take quite a long time to charge the cap to the DCbias level. Aka, expect the signal to max out for some seconds to minutes depending on cutoff freq and gain. \$\endgroup\$ – RobinSt Apr 18 at 20:13
6
Here's something inspired by the first 2 answers. Make a 10-second low pass filter of the input signal and feed that into an op-amp's non-inverting input (+). Then take a 1-second high pass filter of the same input signal, and feed that into the inverting (-) input of the same op-amp.
Fluctuations get subtracted from the average and amplified a lot. If it's too much amplification, a resistor in series with C2 will lower the gain. This also inverts the fluctuation signals. If you want them non-inverted, follow this with a gain of -1 inverting stage.
  • \$\begingroup\$ Thanks for the comment. In this scenario would the 1 kHz sine be replaced with my 0.2V signal? Would this work if the "fluctuations" are squeezes of the pressure gauge at about 1 hz (something like a heartbeat-like pulse)? \$\endgroup\$ – Marty Apr 18 at 23:36
  • \$\begingroup\$ Yep, I forgot to override the default frequency of the sine-wave symbol in the circuit simulator, but I meant it to represent your signal at 1Hz. \$\endgroup\$ – hoosierEE Apr 18 at 23:48
Digital designer here so I'm not certain, but...
The other answers assume high-frequency fluctuations. Instead you want to subtract the 0.2 V and amplify that. You can use a summing amplifier to subtract the offset, if you've got positive and negative supply voltages. I think you can also use an inverting configuration where the non-inverting input is at 0.2V instead of ground.
Sure, just an ordinary inverting op-amp can do that:
Remember that an op-amp wants to make its inputs the same. So if you put 2V on the non-inverting input, and the signal input is also 2V, the output will be 2V.
But say the signal input is 2.1 V. The op-amp wants to make the non-inverting input also 2V, and will have to drive the output higher than 2V to make that happen due to the voltage divider action of R1 and R2. The selection of these resistors thus sets the gain.
Keep in mind any source impedance will effectively add to R2, so if your sensor doesn't already have a low-impedance output, you may want to buffer it.
You have a couple options for realizing V2, since you probably won't want to find a 2V battery. Since the op-amp's input impedance is quite high, this doesn't need to be a low impedance source, so it could be as simple as a potentiometer across the power supply. Of course this will make the circuit somewhat dependent on the supply voltage, and the small but non-zero input current to the op-amp will introduce some error, so if you require high precision you might find an adjustable voltage regulator more suitable.
Use a coupling capacitor prior to the amplifier. The DC signal will be blocked but the fluctuations will pass through.
