I have already designed a buck converter with the following specifications using an MCP19035:
Vin=14V, Vout=1.8V, Fc=63kHz(Crossover frequency), Vref=0.6V, Iout=10A step load High IOH=7.5A step load low IOL=2.5A Fsw=600kHz
My design is working perfectly and I got the expected outputs
Now, I want to design the same converter with the same specifications, using MCP1630V. I have used the circuit given bellow, with the same calculated components for the voltage divider network, the compensation network, and power stage network. Unfortunately my design does not work as expected and I could not figure out the problem
The only thing that I think could be the source of the problem is the ramp generator circuit used in CS pin of this component
please, try to figure out what is the problem in my design
My buck converter circuit
    \$\begingroup\$ Can you explain a little clearer about how the design is not working? Do you have any oscilloscope outputs or data we can see? \$\endgroup\$ – TheAndyEngineer Apr 18 at 7:07
  • \$\begingroup\$ The output of MCP19035 is more stable and clean (in terms of chattering) than the output of MCP1630V, and I think the problem is in the ramp generator circuit, please try to focus on the ramp generator circuit \$\endgroup\$ – luxina pado Apr 18 at 19:00
