I'm trying to create a tester board that will hold some power path components (DC input caps, IGBTs, current sensors) that are normally on the Unit Under Test (UUT).
I'd like to connect these components to the UUT through some spring-loaded probes. Are spring-loaded pins even a good way to do this? Should I be looking into alternate methods? Additionally, are high-current, PCB mount, spring loaded probes a common component or should I expect to not find very many?
This probe is an example of what I'd like to place on the baord SHE-5-B-18.7-G. Unfortunately it's not high enough current.
closed as off-topic by Chris Stratton, The Photon, Oldfart, Dave Tweed Apr 18 at 23:41
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ My go-to source for all things pogo pins is Mill-Max. \$\endgroup\$ – Dave Tweed Apr 18 at 23:46
  • \$\begingroup\$ Thanks! I'll check there! \$\endgroup\$ – Phillip Marks Apr 19 at 0:00
