Hello. I am new to electricity. I currently have 3 DC-AC inverter to drive 3 EL Wires(electroluminescent). The input of the inverter will be 12VDC and the output will be 90VAC. I would like to ask what if I use 3 of these inverters to connect 4 or more EL Wires in parallel? The real question is, what would happen if a load is connected to multiple AC power sources connected in parallel? What exact properties will the circuit have? Feel free to ask for more informations.
If they are not specifically designed to be synchronized to each other and connected in parallel, then you cannot connect them in parallel - they will destroy each other.
