Possible Duplicate:
Using a microphone with an Arduino
Can I plug electret condenser microphone directly in ardunio and read ambient sound level? I imagine those microphones pickup sound like voltage and change accordingly...
Will there be a need to amplify signal? what if I plug in 5 microphones? do I need to amplify each?
My project is very simply, I want to create 5 lights wich will activate based on sound level around them.
  • \$\begingroup\$ You cannot. Search google for "microphone preamp". Also, let's assume you microphone didn't provide an extremely small signal. That signal would still be AC. You have to offset it using a capacitor and a voltage divider. Recently someone asked what can happen to a microcontroller if you exceed the input range. \$\endgroup\$ Commented Oct 11, 2012 at 6:27
  • \$\begingroup\$ And yes, you have to amplify each. Don't worry though, the microphone preamplifier can be a simple circuit to make into a small pcb. \$\endgroup\$ Commented Oct 11, 2012 at 6:28
  • \$\begingroup\$ You don't even need to search google, as this question has been asked and answered many many times. Here's an example. \$\endgroup\$ Commented Oct 11, 2012 at 6:32
  • \$\begingroup\$ to detect different sound levels , I think he need somekind of differential amplifier, where this was used in electrocardiography. \$\endgroup\$ Commented Oct 11, 2012 at 6:32
  • \$\begingroup\$ Not really a duplicate, this question is about using just an electrect microphone capsule (with no additional components), while the referenced question is about a more complex circuit (with amplification, etc.) \$\endgroup\$
    – yoyo
    Commented Jan 4, 2017 at 6:15
