I made a t flip flop using structural modeling in verilog.
module Tflip(input T,input clk,output Q,output Qbar) ;
wire S,R;
and(R,Qbar,T,clk);
and(S,Q,T,clk);
SRLatch srt(S,R,Q,Qbar);
endmodule
module SRLatch(input S,input R, output Q, output Qbar);
nand(Q,R,Qbar);
nand(Qbar,S,Q);
endmodule
And then I tried to make T flip-flop in behavioural modelling. It took me ages to find a neat way to initialise the flip-flop.The below code works great. Is it always required to use a reset of some kind ? Would that make the structural code above wrong?
module T_FF(input T,input rst,input clk,output reg Q);
always@(posedge clk)
begin
if (rst == 1)
Q <= 0;
else if (T)
Q <= !Q;
end
endmodule
I tried to implement a version without a reset signal, but it would only work if the test bench started off a certain way.
Every diagram of T flip-flop i looked for did not show a reset signal, so it took me a lot of time to even understand a reset input was required. It feels like structural modelling a foolproof way of creating things.
The problem with a T FF is that its state always depends on its previous state. So if you have no way of initializing the state, the simulator will always propagate "unknown" on every clock edge.
Of course, in real life, the TFF will always definitely be in one state or the other, and you often don't care exactly which one it is at any given moment, which is why you see no initialization in typical applications.
