In the EVM datasheet schematic, two input beads and 2 output beads are used.
In my application, I drive 56V 5A COB LED. Input voltage is 22-50V, so input current can be ~6-13A. I read on Internet, that beads saturate and lose their filtering efficiency, so, it is better to use beads with current ratings 3-4 times higher. How can I implement such filter, as in the example in the datasheet? There are no ferrite beads with current ratings higher than 11A.
