I'm reading about signed number representation and the book says
-6'd3 // 8-bit negative number stored as 2's complement of 3
Is there a reason as to why a number declared as 6-bit is stored as an 8-bit?
I don't think it is the "sign bits" taking extra bits, as it clearly says 2's complement is used. Even if it is sign bits, then only 1 bit would be required.
    \$\begingroup\$ Looks like a simple typo. \$\endgroup\$ – Dave Tweed Apr 23 at 11:57
  • \$\begingroup\$ That was my next quess. Looking through old similar questions , I see the notation <size><u/s><radix><number> for unsigned/signed. But I haven't heard about it yet in my class. Is it obsolete? If not, does using the notation cause numbers to be stored in the respective r's complement. \$\endgroup\$ – Yasha Apr 23 at 11:59
    \$\begingroup\$ "Is it obsolete" No, that is still the correct syntax for a 'sized' negative number. I also think it is a typo. \$\endgroup\$ – Oldfart Apr 23 at 13:08
It's a typo as commented by DaveTweed and Oldfart.
