I am trying to send commands to a Robosapien (first generation) using an IR LED hooked up to an Arduino. I have seen web pages on attaching a microcontroller directly to the toy, but what I want to do is just send commands via IR.
I found an article by K. Smith that mentioned that the IR commands sent by the Robosapien remote take the following form:
To send the hex code 85:
The IRout signal is held high until a signal is sent. Then a string of five zeros is sent to signify a command is coming. Then the hex code is sent but instead of sending a ‘1’ a ‘1110’ is sent and rather than a ‘0’ a ‘10’ is sent. So $85 looks like this:
Binary:     1    0  0  0  0  1    0  1
Robosapien: 1110 10 10 10 10 1110 10 1110
So I tried the code below:
int bitTime=833;
int IROut =  4;
// The setup() method runs once, when the sketch starts
void setup()   {
  // initialize the IR digital pin as an output:
  pinMode(IROut, OUTPUT);
  Serial.begin(9600);
void test()
  // output high
  digitalWrite(IROut,HIGH);
  delay(1000);
  // 5 zeros
  digitalWrite(IROut,LOW);
  delayMicroseconds(bitTime);
  // send 1110 10 10 10 1110 10 1110
  // 1110
  delayMicroseconds(3*bitTime);
  // 10
  // 10
  // 10
  // 1110
  // 10
  // 1110
   // output high
  delay(1000);
void loop()
  test();
But unfortunately I am not getting any response from the Robosapien. What am I doing wrong?
  • \$\begingroup\$ Uhm... are you using external components to modulate the IR signal over the 39.something KHz carrier? \$\endgroup\$ – Axeman Oct 11 '12 at 14:28
A bit time of 833 µs implies a data rate of 1200 bps. I don't know anything about Robosapien, but my first thought is that this signal is possibly meant to be the keying (envelope) imposed on a higher-frequency (e.g., 38 kHz) IR carrier signal.
Can you provide a link to the K. Smith article for reference?
  • \$\begingroup\$ Precisely. Robosapien AFAIR (I've played with that thing years ago) asks for a 1200 bps signal over a 39.2 KHz carrier. \$\endgroup\$ – Axeman Oct 11 '12 at 14:42
  • \$\begingroup\$ Thanks, Dave. Here is the link to the article: docstoc.com/docs/27902404/Robosapien-Project \$\endgroup\$ – M-V Oct 11 '12 at 15:27
  • \$\begingroup\$ Dave, you've pointed me in the right direction. This is all new stuff to me - I'll look into how to generate the carrier signal. \$\endgroup\$ – M-V Oct 11 '12 at 15:32
