I like to consider myself fairly experienced in Electronics Design, but upon being contracted to review this schematic I'm a little stumped. This is basically the output stage of a boost power supply:
I've drawn in the red lines to symbolise where the power actually flows. The MOSFET Q2 on the top left makes sense (although there is no base resistor for Q3, which is the first mistake I pointed out. 3.3V from a micro directly to a 0.7V base-emitter diode, youch!). This is just a P-FET power switch.
What's weirder, but, is after this - the Q4/Q5 pair. Q4 is another P-doped transistor acting as a switch, but the net driving its base in Q5 - and what's driving Q5? The output of Q4! It's a paradox if you ask me. There are two main concerns from me:
- The first is, what's the actual point of this? The only thing I can think of is, assuming Q4 (and thus Q5) turns on by "default" if the output +Vout is shorted to GND, this turns off Q5, which turns off Q4, which disconnects the output voltage from shorting directly to said GND. Fair enough, if this is what it's for - if it's not though, please do correct me?
- The second is, removing my assumption, will this even turn on in the first place? If Q4 was a depletion mode P-MOSFET, I would say yes as this would be "on" by default, let 12V flow through in the "initial" state, and then turn on Q5 until the output +Vout was shorted to GND. In this case, but, this is just a plain-old PNP BJT which, unless I'm crazy, is "off" by default. Thus, it won't ever turn on.
Thanks. Any insight from people would be great, as it seems like a handy little tool for preventing short-circuit overcurrent (although these days, this sort of protection is built into a lot of chips internally). But it looks to me like it hasn't quite been executed correctly, and it needs to be a depletion mode MOSFET there instead so it at least has a defined initial state.
