I'm struggling a little bit here with the LM3880DBV circuit usage in a multi rail power supply circuit
So, here is my power supply circuit block schematic:
Blocks Schematic
And this is how I sequenced my circuit:
Sequence
My problem is I don't know where to put the sequencer circuit in my main power supply design schematic! As in the above schematic, it looks like the sequencer has to be connected to the end of the last output which is so confusing!!!! While in the LM3880DBV datasheet it seems to be placed before the generated outputs, as shown here:
The last output circuit:
last output
Study your block diagram more closely (I've added explicit control lines to make it easier for you): -
The lower output regulator is permanently activated hence, the voltage it generates is suitable for a supervisory controller like the LM3880. Just because it sits at the bottom of the diagram it doesn't mean it is somehow lower in status.
It is - it controls supply 2 to 5 (not 6) via enable inputs. Just study your schematic.
  • \$\begingroup\$ Awesome, very intuitive easy to follow answer! \$\endgroup\$
    – user186623
    Apr 24 '19 at 11:33
  • \$\begingroup\$ last question, where I'm gonna connect the EN pin of the lm3880 with, or I just leave it unconnected? I attached the last output circuit! \$\endgroup\$
    – user186623
    Apr 24 '19 at 11:45
  • \$\begingroup\$ The enable pin is crucial to how sequencing works and you should read section 7 of the LM3880 data sheet. I can't tell you how to connect it because it depends entirely on what your expectations and functionality are. \$\endgroup\$
    Apr 24 '19 at 12:07
  • \$\begingroup\$ got it! Thanks again, Andy! \$\endgroup\$
    – user186623
    Apr 24 '19 at 13:16
