I'm using ESP8266 ESP-01 for wifi data transfer.
When I send the request for 80 server's port, the data is successfully returned.
REQ: GET / HTTP/1.1\r\nHost: server.com\r\n\r\n
But when I send this request over 443 server's port, the data received is "Recv 50 bytes... ...SEND OK..."
It's possibly an ESP or an HTTPS Headers problem? What i mean is what is needed to transform the Headers from HTTP to HTTPS (I did'nt saw any diference in Postman, but in Postman works only changing the server's port)?
  • Sequence in HTTP:
AT+CIPSTART="TCP","myserver.com\",80"\r\n
AT+CIPSEND=PKG_SIZE\r\n
GET / HTTP/1.1\r\nHost: myserver.com\r\n
Works OK.
  • Sequence in HTTPS:
AT+CIPSTART="TCP","myserver.com\",443"\r\n
Doesn't work.
  • \$\begingroup\$ How many bytes are you actually sending? \$\endgroup\$ – Egor Tamarin Apr 25 '19 at 6:52
  • \$\begingroup\$ The reponse is "Recv x bytes" where x is the bytes sent in my request. The GET above have 50 bytes. \$\endgroup\$ – Henrique Apr 25 '19 at 12:53
    \$\begingroup\$ Are you using the AT firmware? Show the AT commands you use. \$\endgroup\$ – JimmyB Apr 25 '19 at 14:13
Try to connect via SSL instead of bare TCP:
AT+CIPSTART="SSL","myserver.com",443
  • \$\begingroup\$ The module reposnds: "busy p...\r\n\r\nERROR\r\nCLOSED\r\n. Ive found in another forum that this model (ESP-01) maybe doesn't support HTTPS... \$\endgroup\$ – Henrique Apr 30 '19 at 0:41
  • \$\begingroup\$ Jimmy, thank you. I tested in ESP32 and worked in 443 PORT. in ESP8266_ESP01 still doesn't work but ESP32 is far enough. \$\endgroup\$ – Henrique May 1 '19 at 19:36
