I have a CPLD XC9536XL-10VQG44C. On this CPLD I have one input "INPUT_4", one clock at 4MHz "clock" and 2 outputs "OUTPUT4_1" and "OUTPUT4_2", I also have 1 LED to drive that takes the same value than the input.
What I want to do is:
- When INPUT_4 goes high, turn OUTPUT4_1 high and OUTPUT4_2 low for 50ms then put them both back to low.
- When INPUT_4 goes low, turn OUTPUT4_1 as low and OUTPUT4_2 high for 50ms then put them both back to low.
So what I wanted to do was look for the input, and as soon as there is a change on it, do the corresponding change on the output and starting counting the 100ms. When the 50ms is finished, put them back low.
I appreciate that it is probably easier to do with a microcontroller but I cannot change the hardware.
For that I wrote that vhdl:
entity test_vhdl is
Port ( Input_4 : in STD_LOGIC;
Output4_1 : out STD_LOGIC;
Output4_2 : out STD_LOGIC;
LED_4 : out STD_LOGIC;
Clock : in STD_LOGIC); --4MHz
end test_vhdl;
architecture Behavioral of test_vhdl is
constant overflow : natural := 200000; --50ms pulse with a 4MHz frequency
signal COUNTER_4 : natural range 0 to overflow;
begin
LED_4<=Input_4;
output4: process(Input_4, Clock) is
begin
if rising_edge(Input_4)then
Output4_1 <= '1';
Output4_2 <= '0';
COUNTER_4 <= 1;
elsif falling_edge(Input_4) then
Output4_1 <= '0';
Output4_2 <= '1';
COUNTER_4 <= 1;
end if;
else
if rising_edge(Clock) then
if COUNTER_4 /= 0 then
COUNTER_4 <= COUNTER_4 + 1;
if COUNTER_4 = overflow-1 then
Output4_1 <= '0';
Output4_2 <= '0';
COUNTER_4 <= 0;
end if;
end if;
end if;
end if;
end process output4;
end Behavioral;
I simulated it and it works fine. But when I try to synthesize it I get the error:
Signal Output4_1 cannot be synthesized, bad synchronous description. The description style you are using to describe a synchronous element (register, memory, etc.) is not supported in the current software release.
Maybe it comes from the fact that I check the rising edge of two different signals in the same process. I am still in the learning curve of VHDL, how can I resolve this problem or is there a better way of doing what I need to?
else
? As written it looks like your code will still respond to clock edges while the reset signal is asserted. Real flip flops don't work that way, so it can't be synthesized. \$\endgroup\$
