I want to solder a USB A connector to my Trinket m0 instead of using an adaptor cable to plug into my PC.
Can I access Trinket m0 USB through GPIO pins?
I have looked at the description of the pinouts, but I cannot work out if it is a yes or no.
Any ideas?
closed as unclear what you're asking by Chris Stratton, RoyC, pipe, DoxyLover, Lior Bilia May 12 at 2:04
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ This question doesn't make much sense. The trinket has a USB connector, that is where you should connect to. \$\endgroup\$ – Chris Stratton Apr 26 at 2:55
Lucky for you, Adafruit shares the schematics and layout for all their boards. The Trinket M0 schematic is here https://learn.adafruit.com/assets/45723 . Copied for reference: enter image description here
As you can see, no, the USB doesn't connect to any of the breakout pins. It goes straight into the microcontroller.
