I want to better understand how Electronic Speed Controllers (ESC) work for BLDC motors. Specifically, I am trying to understand battery current draw.
Question 1: When an ESC is rated at 200 amps nominal and 500 amps peak is it safe to assume that the draw on the battery pack will not exceed 200 amps? I'm rationalizing this in my head by assuming the capacitors in the ESC are just discharging more current than normal for short durations when this 'peak' value is experienced. I'm also assuming it will never try to pull 500 amps from the battery pack. If this isn't right, please explain.
Question 2: If the motor is run indefinitely at max throttle (theoretically) will the ESC draw 200 amps from the battery continuously or less than that? I'm now thinking the draw will be more along the RMS value of the output pulse wave. This would explain why the ESC input wires from the battery pack are relatively small in relation to the output current rating. When I see 200 amps I think of thick 2/0 awg gauge wire, not the 6 awg or 8 awg gauge wires I see on my ESC.
Question 3: (slightly off topic) To modulate motor speed does the ESC restrict current flow or voltage? I assume it is current, I just want verification. Let's say the throttle is at 10% and assume the throttle curve is linear. I just want to understand the theory of how ESC's work at a high level.
Much thanks!
