This is my Task which should be done in MATLAB. I have the MATLAB codes but need some changes.
1) As written in the task the L and H should be greater than 20h and impedance should be 50 ohms. Please help to adjust these parameters so that after changing the L and H I still get 50 ohms.
2) In the codes, in the last, I am not able to understand the Tolerance testing Part.
Codes:
%Clearing variables in memory and Matlab command screen
close all;
clear all;
clc;
%Problem data
L = 10;
H = 4.5;
h = 0.5;
w = 0.6;
epsilon_0 = 8.854*10^-12;
epsilon_r = 3.05*epsilon_0;
%Dimensions of the simulation grid in x (xdim) and y (ydim) directions
xdim=50;
ydim=50;
dx = L/xdim;
dy = H/ydim;
N_strip1x = floor((L-h)/2/dx); % number of node along x axis of the left strip
N_strip2x = floor(N_strip1x + h/dx); % number of node along x axis of the left strip
N_strip1y = floor((H-w)/2/dy);
N_strip2y = floor(N_strip1y + w/dy);
r = cos(pi/(xdim/L))+cos(pi/(H/ydim));
alpha = 1;
%Initializing initial Potential matrix & boundary conditions for V_init
V=zeros(xdim,ydim);
V(N_strip1x,N_strip1y:N_strip2y) = 1;
V(N_strip2x,N_strip1y:N_strip2y) = 1;
%Initializing maximum number of iterations
max_iterations = 500;
Z0 = zeros(1,max_iterations);
figure,
for i = 1:max_iterations
    clc
    display(['iteration n° ',num2str(i),'/',num2str(max_iterations)])
    V_old = V;
    for x = 2:xdim-1
        for y = 2:ydim-1
            % evaluate on the same line of the strips
             if x == N_strip1x && y > N_strip2y && y  N_strip2y && y  N_strip1x
                V(x,y)=epsilon_r*V_old(x,y)+alpha*(((epsilon_r*V_old(x-1,y)+epsilon_r*V_old(x+1,y)+epsilon_r*V_old(x,y-1)+epsilon_r*V_old(x,y+1))/4)-epsilon_r*V_old(x,y));
                V(x,y) = (1/epsilon_r) * V(x,y);
            end
            %evaluate outside the strips
            if x > N_strip2x || x  N_strip2y && y  N_strip2y && y  N_strip1x
                    V(x,y)=epsilon_r*V_old(x,y)+omega(o)*(((epsilon_r*V_old(x-1,y)+epsilon_r*V_old(x+1,y)+epsilon_r*V_old(x,y-1)+epsilon_r*V_old(x,y+1))/4)-epsilon_r*V_old(x,y));
                end
                if x > N_strip2x || x  0
            break
        end
    end
    n_iterations(1,o) = i;
end
figure,
plot(omega,n_iterations);
xlim([0.9 1.02]);
xlabel('Omega')
ylabel('Number of iteration')
title('Plot of number of iteration versus omega')
This shows how different parameters were taken
Formula used for SOR method
  • \$\begingroup\$ Can you share the resource the question is borrowed from? \$\endgroup\$
    – McSuperbX1
    Dec 9, 2023 at 10:52
The point of this requirement is that if \$L\$ and \$H\$ are large compared to \$W\$ and \$h\$, then they will not affect the characteristic impedance much. Adjusting \$L\$ or \$H\$ should not change \$Z_0\$ noticeably.
In general, increasing \$W\$ should reduce \$Z_0\$ and increasing \$h\$ should increase \$Z_0\$. That should give you enough to nail down a combination of \$W\$ and \$h\$ that reaches \$Z_0=50\ \Omega \pm 5\ \Omega\$ within 3 or 4 tries.
I can't read your codes, but this likely means simulating small changes in \$W\$ and \$h\$ to see how big a change they cause in \$Z_0\$.
  • \$\begingroup\$ Thanks for the valuable suggestion. I have to change w, L and H but 'h' is fixed i.e. 0.5. L and H should be greater than 20h i.e. 10. \$\endgroup\$
    – user170106
    Apr 27, 2019 at 21:28
    \$\begingroup\$ Changing L and H should not (if you start with them big enough) affect \$Z_0\$. Just adjust W. \$\endgroup\$
    – The Photon
    Apr 27, 2019 at 21:29
    \$\begingroup\$ Hint: if you want to cheat, remember the method of images. Your scenario is like a microstrip considered with the ground plane removed according to the method of images. And there are lots of microstrip solvers out there that can give you W for a desired \$Z_0\$. At the very least this can give you a very close guess for a starting point for your optimization. \$\endgroup\$
    – The Photon
    Apr 27, 2019 at 21:33
    \$\begingroup\$ You could also speed up your simulator by considering the symmetry plane in this problem and replacing it with a ground plane, giving you half the volume to perform the FEM in. \$\endgroup\$
    – The Photon
    Apr 27, 2019 at 21:34
