We could use boolean algebra to analyse the digital circuit and use boolean simplification to optimise the circuit.
In boolean expression "1 + A" is 1, whatever A is 1 or 0.
But in the real digital world, the result would be 0 if expression is "1+1" and result is 1 bit. Does it mean we can't use the boolean algebra in any electronic case or I misunderstand something?
closed as unclear what you're asking by Marcus Müller, Warren Hill, Finbarr, RoyC, Bimpelrekkie Apr 29 at 9:08
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ It's "boolean", like you've used it once in your question, not "boolen" like you used thrice :) No big deal, I fixed that for you. You're wrong however. You're confusing the "OR" with the "XOR" operation, and these are two different things. What "+" means depends on context, but if nothing else is said, I'd assume "OR" \$\endgroup\$ – Marcus Müller Apr 28 at 11:25
  • \$\begingroup\$ As others have pointed out, boolean algebra chooses to define the meaning of the symbol \$+\$ to indicate "inclusive OR." (There are good reasons for the choice.) That algebra also chooses to define the meaning of the symbol \$\oplus\$ to indicate "exclusive OR." You need to avoid conflating the two into a mush. They mean different things. So you need to keep your head straight when reading forward. If someone writes "OR" without either "inclusive or exclusive" then you should probably assume a priority for \$+\$ ("inclusive OR"), unless the context makes it otherwise clear to be \$\oplus\$. \$\endgroup\$ – jonk Apr 28 at 16:55
The + symbol is "OR" rather than "sum" when discussing boolean algebra.
The problem you are having is that you are confusing the usual meaning of + in mathematics with the boolean operator + for OR.
The function you describe is the boolean logic XOR (exlusive OR.)
This is also known as a half adder. 1 XOR 1 gives 0.
