Here's the pinout diagram for an LM358
lm358 dual op-amp
Here's the pinout diagram for the LM386:
lm386 op-amp
Here's a very basic circuit showing an audio amplifier created using an LM386:
audio amplifier via lm386
  • If I built the equivalent circuit using the LM358, would it work in a similar way? Or would it fail since the chip has no gain? (I've built the equivalent circuit and it did not seem to work. Didn't know if I was doing something else incorrectly though.)
  • Is there a way to compensate for the lack of gain in the LM358?
  • Is it possible to create a very simple audio amplifier using an LM358 or is it basically not feasible due to its characteristics / abilities?
    \$\begingroup\$ what do you mean has no gain? the LM358 has enormous gain, that's the entire point of an op amp. \$\endgroup\$
    – Hearth
    Commented Apr 29, 2019 at 0:13
    \$\begingroup\$ They're not interchangeable. LM386 is an audio amp, intended to drive a speaker. It's not any kind of opamp like the LM358 is. \$\endgroup\$
    – brhans
    Commented Apr 29, 2019 at 0:32
  • \$\begingroup\$ Never use the LM358 for audio. Even for intermediate stages. Too many better choices, so find something better. And as others have mentioned the LM386 is a power amplifier and never used for similar applications as the LM358. Different horses for different courses, entirely. You can see some of the LM380 (similar to the LM386) here. \$\endgroup\$
    – jonk
    Commented Apr 29, 2019 at 3:12
You can add feedback resistors to obtain a reasonable gain. But, your problem is that the LM358 isn't designed to drive a speaker.
They're two completely different parts, even though they share a schematic symbol.
The LM358 is a dual op amp, the LM386 is a power amplifier with default gain set and designed to drive a small speaker.
I recently tried to see if I could get the lm358n to work as an audio amp but had no luck so I would just go for the lm386
    \$\begingroup\$ Welcome to EE.SE but it's not clear what the point of your post is. Luck isn't going to make an op-amp work as a power amplifier. The explanation has been given several times in the other answers. \$\endgroup\$
    – Transistor
    Commented Jun 10, 2020 at 21:29
