If I have two metal plates, with P1 connected to V+, and P2 connected to GND, how can I alternate the polarity of these two plates? I wish to have P1 connected to GND, and P2 connected to V+. Then swap polarity again, and so forth. Is there such a circuit for this type of polarity switching?
  • \$\begingroup\$ What are the dimensions of the plates? And define 'rapidly'. \$\endgroup\$ – Chu Apr 29 at 6:39
  • \$\begingroup\$ Are you building a synchrotron? \$\endgroup\$ – Jasen Apr 29 at 9:27
  • \$\begingroup\$ What is V+ max? \$\endgroup\$ – Sunnyskyguy EE75 Apr 29 at 11:25
  • \$\begingroup\$ It looks like I was overthinking this. I'm basically looking for an H-bridge sort of thing. A double-pole-double-throw switch as answered by Drew works too. I only need a switch of polarity once every second, or even longer intervals. The voltage would likely be 12V to feed the motor driver. \$\endgroup\$ – user3211857 Apr 30 at 7:08
The answer will depend on how fast, and what voltage. For occasional switching you can use a dpdt relay wired as a reverser.
I found a tutorial for this here. If that dies just search "DPDT reverse switch" or "DPDT reverse relay".
To go faster (like many times per second), you'll want to use an H bridge. For lowish voltages, you can get a fully integrated module from amazon based on the LM298N motor driver.
For higher voltages, you might have to build your own H bridge using high voltage components.
  • \$\begingroup\$ Thank you. I apologize for the late response. I did some research and decided the H-bridge motor driver board is what I'm looking for. I can control the switching with an Arduino. \$\endgroup\$ – user3211857 Apr 30 at 7:05
