I am new to the TI MSP430G2553. I would like to send a PWM signal like in this picture:
(Image source: Adafruit - Understanding Infrared Signals)
However I can't do that, because I don't know how to stop (finish) the PWM signal. Here is my PWM signal code:
void configTimer(void) // this function sends infinite pwm signal when button is pressed
TA1CCR0 = 26-1; // Period
TA1CCR1 = 13; // 50% dutycycle
TA1CCTL1 |= OUTMOD_6; // Reset/Set
TA1CTL = TASSEL_1 + MC_1 + TACLR;
I tried:
TA1CTL1=0;
TA1CTL = MC_0;
- set default value of
TA1CCR1 = 0
, when button pressed setTA1CCR1 = 13;
and later__delay_cycles(any number);
However they didn't work.
Thanks in advance.
Edit: My last try Edit2: Edit: I think can't use my timer interrupt my counter is always 0.
define TIMER0_A1_VECTOR (8u * 2u) /* 0xFFF0 Timer0)A CC1, TA0 */
define TIMER0_A0_VECTOR (9u * 2u) /* 0xFFF2 Timer0_A CC0 */
This is definiton of timer0 vector. How should i write it in my code?
#include <msp430.h>
void startTimer(void);
unsigned char counter=0;
void start2Timer(void);
int main(void)
WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
BCSCTL1 = CALBC1_1MHZ; // Set range
DCOCTL = CALDCO_1MHZ;
CCTL0 = CCIE;
P2DIR |= BIT2;
P2SEL |= BIT2;// Select pwm pin (transmitter)
P2OUT=0x00;
while(1){
if((P1IN & BIT4)!=BIT4) //button is pressed
startTimer();
start2Timer();
void startTimer(void) // pwm signal
TA1CCR0 = 26-1; // Period Register
TA1CCR1 = 13; // TA1.1 25% dutycycle
TA1CCTL1 |= OUTMOD_6; // TA1CCR1, Reset/Set
void start2Timer(void) // trying to stop after 50 ms
CCR0 = 5000; // CCR0 5 ms
TACTL = TASSEL_2 + MC_2; //
#pragma vector=TIMER0_A0_VECTOR // Timer0_A0
__interrupt void Timer_A (void)
if(++counter==10){ // is counter 10 (5*10=ms)
TA1CCR1 = 0; ; // Stop pwm
counter = 0;
TA1CTL = MC_0
should work. What actually happened when you tried that? \$\endgroup\$ – The Photon Apr 29 '19 at 23:17TA1CTL=MC_0
should stop the timer. If you have a different issue, you should edit the question to explain what the issue is. \$\endgroup\$ – The Photon Apr 29 '19 at 23:28delay_cycles()
to produce delay between output changes, you don't need to use the timer. You can use the timer when you want to change the output without your code writing to P2OUT. Also, if you have the pin configured as a timer pin, writing to P2OUT won't change the state of the pin. If you have the pin configured as a GPIO pin, then the timer can't control it. \$\endgroup\$ – The Photon Apr 29 '19 at 23:34
