7
I'm working on a PCB of a drone. It had some failed MOSFETs that I've replaced using hot air soldering.
It works fine again, but parts of the PCB were covered in a glue-like substance which I think is conformal coating. I figured the coating would probably interfere with the hot-air soldering, so prior to applying the hot air, I removed parts of it using paint thinner. Now I have a few questions:
  1. What is the purpose of this coating?
I suspect it's to prevent malfunction of the PCB when it gets moist. Maybe when the drone would fly in moist air or fog. The drone really isn't made to fly in the rain. I'm confused about it because it's only partial - only at the places where components are. I'd expect a coating like that to be applied over the whole surface of the PCB. Or are traces and vias not prone to getting moist because of the solder mask? Could there be another reason for a coating like this?
  1. Is conformal coating ever used to prevent service to a board? Like when a manufacturer would rather sell new boards or new devices than having a technician service a broken PCB? Removing the coating before service is a lot of work and might discourage the technician.
  2. I've taken off the coating at the place I needed to do the rework. But it takes quite some scrubbing with paint thinner because the surface is very uneven (mounted SMD parts.) The coating becomes very sticky when in contact with the thinner, but needs scrubbing to come off. So where the coating is not completely removed, there is now a mix of re-hardened coating and fibers from the cloth that I was using. (When the thinner evaporates, the coating becomes hard again.) The fibers are very small, and best seen with a magnification glass (hence no photo), but are also in-between the legs of the ICs (see picture 2.)
Is it likely that this will lead to problems? E.g. if moisture would be trapped in those fibers?
  1. Is it advisable to re-apply the coating? If so: Are there any household products I could use for that? I was thinking about hairspray. Or is that a really bad idea?
Picture 1
Picture 1: Partially applied coating. It has a blue-ish/transparent color to it.
Picture 2
Picture 2: Closeup of the part I did rework on, prior to the rework. The coating on the bottom of the PCB (picture 1) was clearly applied nicer than the top (this picture). On the top, there is quite a thick layer at some places. I removed the coating near the MOSFETs, but also around the two high pin count ICs (MOSFET driver and microcontroller).
Conformal coating is used to increase mechanical toughness (like abrasion), shock dampening, and to protect against moisture, dirt, grime, and arcing.
Certain types of conformal coating are very nasty to get off if you need re work so they can be used to prevent service. But normally you would just use epoxy for that.
Silicone conformal coatings can be soldered through for rework.
Note if conformal coating is applied improperly it can do more harm than good. Silicone, for example does prevent moisture from getting to the PCB, but it is not completely impermeable. Therefore, if air pockets exist, the moisture can permeate through and accumulate against the PCB where they it will never leave.
Do NOT coat a board with anything that it is not meant to be coated with. Hairspray, for example, is meant to stick and stiffen things, not seal them off. Furthermore, isn't hairspray flammable?
The most common types of conformal coating that can be applied by a normal person is acrylic, polyurethane, and silicone. I prefer silicone for reworkability. It's feels softish and pliable. The others are nasty get off.
Paraylene is the really nice one but requires vacuum deposition equipment so it's NASA/military stuff.
1) What is the purpose of this coating?
Generally it's to keep humidity or dirt away from components. This site has a good write up on it.
2) Is conformal coating ever used to prevent service to a board?
Not that I know of, if people want to hamper efforts to service a product, usually potting is used, which is an epoxy that coats the board and all the components usually more than 1/4" thick. Very difficult to remove without collateral damage. Conformal coating can make it more difficult to service, but people that don't want parts serviced usually start by grinding off component ID's, then you have to etch off the package and find a nice microscope.
Is [the fibers in the conformal coating] likely that this will lead to problems?
Yes, if the fibers are not covered with conformal coating they could provide a pathway that penetrates the conformal coating. Ideally they should be removed before recoating, but this might not be possible. Acetone might be a better way to get the coating off, but whatever you use, be careful as some solvents can damage components.
4) Is it advisable to re-apply the coating? If so: Are there any household products I could use for that? I was thinking about hairspray? Or is that a really bad idea?
Ha! Hairspray is not a conformal coating, I suppose they have the same consistency but are not even close to being chemically similar.
There are many places that sell conformal coatings, including digikey
  • \$\begingroup\$ In a drone, might it be to prevent vibration damage? \$\endgroup\$ Apr 30, 2019 at 18:42
  • \$\begingroup\$ Silicone would because it's soft. I don't think the hard conformal coatings like acrylic and polyurethane would be as helpful. From the sounds of it, your conformal coating is not silicone so it's probably just to seal it from the elements due to the exposed PCB being in the great outdoors on a drone. \$\endgroup\$
    – DKNguyen
    Apr 30, 2019 at 18:44
    \$\begingroup\$ Could be, I was thinking that they coat it in the drone because rapid changes in temperature and pressure/humidity with elevation could lead to condensation. And a few people like to fly them through low clouds \$\endgroup\$
    – Voltage Spike
    \$\begingroup\$ oscarliang.com/waterproofing-drone-electronics \$\endgroup\$
    – Voltage Spike
    Apr 30, 2019 at 18:47
Please do not use hairspray! I highly recommend re-applying coating. I have used conformal coating, specifically silicone in the past with great success. It's also a lot easier to rework if needed.
Great source of information about conformal coating and the different types on this site if your just looking for information on it and still deciding what to use: https://www.paryleneconformalcoating.com/conformal-coating/
