Is it dangerous to run a permanent magnet alternator open-circuited? No current can flow so is all the power dissipated as heat? Is there even power generated in the inductive coils?
Since power is current multiplied by voltage, and no current is flowing, it is not power dissipation you need to worry about.
Voltage will be generated, but it shouldn't cause a problem.
| improve this answer | |
  • \$\begingroup\$ Hi @evildemonic, thanks for responding. What is your source for this? Did you read it in a textbook or experience it from working with PM alternators, or are you just referencing basic circuits theory? \$\endgroup\$ – user211492 May 1 '19 at 18:02
  • \$\begingroup\$ This is from basic electronics theory and general experience with motors and alternators of all types. A voltage will be produced, but actual power will not be generated. \$\endgroup\$ – evildemonic May 1 '19 at 18:10
  • \$\begingroup\$ I heard from someone else, who also has some experience with motors and alternators, that after enough time running open-circuit it will overheat. So I don't think I can come to a conclusion one way or another before testing it myself. \$\endgroup\$ – user211492 May 2 '19 at 16:48
