I built a PCB filter in Class "Band-pass" with center frequency of 2.4 GHz. The board has two SMA's (input 1 & output 2).
S(1,2) looks like this:
The frequency is good, However, the attenuation is bad. My problem is that my Reflection signal S(1,1) looks like:
(I thought I would see a valley going down at the 2.4 GHz frequency)
(Note: I am using a transmission line design)
The PCB Circuit:
Specifications:
Filter Type: Chebychev bandpass
Ripple: 0.5 dB
Ctr. Freq.: 2.437 GHz
Att.: 50 dB @ 2.459 GHz
Tgt. BW: 20 MHz
Substrate: Rogers RO4350B
εr : 3.48 +/- 0.005
Tsx: 1.524 mm
TCu: 35 μm
Board + Layout: enter image description here
  • \$\begingroup\$ Please share the datasheet of the device you're testing. \$\endgroup\$
    – The Photon
    May 1, 2019 at 15:29
  • \$\begingroup\$ What is the spacing between the elements of your filter? \$\endgroup\$ May 1, 2019 at 15:45
  • \$\begingroup\$ It is a PCB board I designed, should I attach an image of it? \$\endgroup\$ May 1, 2019 at 15:46
    \$\begingroup\$ The answer is that you've not built a PCB filter, you've built a PCB thing which is almost totally mismatched. If you want help with the design, then you need to post what type of filter you're trying to design, what order, what specs (bandwidth, attenuation depth at what offset), what design program you've used, and a picture of the board. \$\endgroup\$
    – Neil_UK
    May 1, 2019 at 16:35
    \$\begingroup\$ Those look to be humungeous great gaps, what synthesis program came up with those? A gap of 4 or 5 substrate thicknesses is essentially not coupled, unless, perhaps, you have extraordinarly high Q resonators, which you don't have with copper. Are you targetting a very very small bandwidth? \$\endgroup\$
    – Neil_UK
    May 1, 2019 at 18:23
Thanks, everybody. I think I solved it. The reason was the wires (cables) resistance was high so it was causing the attenuation. I replaced one of them and I was able to see better spectrum.
