I have a particle counter HPMA115S0 which has a UART communication interface. I bought a TTL UART to RS485 Converter Module to make it work with a PLC over Modbus RTU protocol.
I usually work with devices that have RS485 serial communication standard but those devices have all the information I need to make them work over a Modbus serial communication protocol (PLC as a master) such as the ID and the baud rate and the registers' addresses which contain the data to request.
However, with HPMA115S0 I don't know what the ID would be, what is the register address of the measurement value and so on. So can I make this device with UART communication to work over Modbus serial protocol by using the UART to RS485 converter?
