I am doing a study on Improvements in biasing and compensation of CMOS opamp.
Do you guys know how to come up with the equation for RDS4C ?
a new gm-tracking lead compensation resistor
  • \$\begingroup\$ I think it would be useful if you showed what you tried. Where are you stuck? Do you know where to begin? Conductance is the reciprocal of resistance, that's for sure. And the circuit holds gm2E=gm4C. Now this conductance value must be for the conductance of the drain-source. \$\endgroup\$ May 5, 2019 at 14:07
  • \$\begingroup\$ @DanielTork gm2E=gm4C ? Did you have a typing mistake or something else ? \$\endgroup\$
    – kevin998x
    May 5, 2019 at 14:19
  • \$\begingroup\$ I'm not sure what you mean. Please explain. \$\endgroup\$ May 5, 2019 at 14:23
  • \$\begingroup\$ What do you know about your question that could be useful for solving it? \$\endgroup\$ May 5, 2019 at 14:26
Someone else had derived the answer
