The boolean expression:
y= (a'+b) * (b(c'+d')) = (a'+b) * (bc' + bd')
is given.
Find out the disjunctive normal form to this boolean expression.
My suggestion:
y= a'bc'd' + a'bc'd + a'bcd' + abc'd' + abc'd+abcd'
only when these terms are true the function is 1 and otherwise not. (=0)
Is the DNF right?
Thanks for the help.
Edit: Here ist the truth table for the boolean expression:
  • \$\begingroup\$ You might notice that a has no effect on the output. \$\endgroup\$
    – Finbarr
    May 5 '19 at 12:01
That looks good your original equation reduces to (bc' + bd') which is what you have put in your truth table and then extracted in DNF.
Edit to clarify reduction of original equation.
(a'+b) * (bc' + bd')= a'(bc' + bd')+b(bc' + bd')
              = a'(bc' + bd')+(bc' + bd')
              = (bc' + bd')
  • \$\begingroup\$ the simplified boolean equation would be b(c'+d'), so i could simplify the DNF to y= bc'd' + bc'd + bcd' + bc'd' + bc'd+bcd' , right? \$\endgroup\$ May 5 '19 at 12:17
  • \$\begingroup\$ @lightsodium DNF requires all the variables to be present in all of the terms. \$\endgroup\$
    – RoyC
    May 5 '19 at 12:19
  • \$\begingroup\$ oh,thanks! so it still would be y= a'bc'd' + a'bc'd + a'bcd' + abc'd' + abc'd+abcd' \$\endgroup\$ May 5 '19 at 12:22
  • \$\begingroup\$ "that looks good your original equation reduces to (bc' + bd')": how can I read this just out of the truth table? and not by using laws to reduce the equation \$\endgroup\$ May 5 '19 at 12:42
  • \$\begingroup\$ You can't you have to use the laws of boolean algebra to get to (bc' + bd'). After you put this in your truth table you can read out the DNF form. \$\endgroup\$
    – RoyC
    May 5 '19 at 13:01
