I am using this component for a project, however, when reading the datasheet I have just become confused about a couple of things.
Datasheet : http://www.ti.com/lit/ds/slvs569f/slvs569f.pdf
I am just trying to calculate the output voltage ripple for my Cout capacitor. Just say the ESR was 0.05 ohms, for example, is the inductor ripple current : (IL1(pk)-ILoad(max))*2. Hence say ILoadmax was 1A, then just say I get the IL1(pk) as 1.2A. Hence is the inductor ripple current referring to the peak to peak inductor ripple current? So it would just be 0.4 A? Hence the output ripple voltage would be 0.4*0.05?
*Note the numbers used here are just for example purposes
