I am trying to implement a complementary filter in my system but I do not quite understand what "dt" means and how should I find out the "dt" in the complementary filter equation.
I found the complementary filter equation here.
This is the equation:
$$angle = 0.98 * (angle + gyrData * dt) + 0.02 * (accData)$$
This is the code I am using now:
while n!= 10:
data = bus.read_i2c_block_data(0x68, 0x3B, 6)
xAccl = data[0] * 256 + data[1]
if xAccl > 32767 :
        xAccl -= 65536
yAccl = data[2] * 256 + data[3]
if yAccl > 32767 :
        yAccl -= 65536
zAccl = data[4] * 256 + data[5]
if zAccl > 32767 :
        zAccl -= 65536
data = bus.read_i2c_block_data(0x68, 0x43, 6)
xGyro = data[0] * 256 + data[1]
if xGyro > 32767 :
        xGyro -= 65536
yGyro = data[2] * 256 + data[3]
if yGyro > 32767 :
        yGyro -= 65536
zGyro = data[4] * 256 + data[5]
if zGyro > 32767 :
        zGyro -= 65536
totZdata += zAccl
totXdata += xAccl
totYdata += yAccl
totGyroXdata += xGyro
totGyroYdata += yGyro
totGyroZdata += zGyro
zAcclG = (zAccl - AcclzOff) / Accl_scale
xAcclG = (xAccl - AcclxOff) / Accl_scale
yAcclG = (yAccl - AcclyOff) / Accl_scale
xGyroDPS = (xGyro - GyroxOff) / Gyro_scale
yGyroDPS = (yGyro - GyroyOff) / Gyro_scale
zGyroDPS = (zGyro - GyrozOff) / Gyro_scale
print ("Acceleration in X-Axis : %.2f G" %xAcclG)
print ("Acceleration in Y-Axis : %.2f G" %yAcclG)
print ("Acceleration in Z-Axis : %.2f G" %zAcclG)
print (" X rotation : %f" % (get_x_rotation(xAcclG, yAcclG, zAcclG)))
print (" Y rotation : %f" % (get_y_rotation(xAcclG, yAcclG, zAcclG)))
print ("X-Axis of Rotation : %.2f" %xGyroDPS)
print ("Y-Axis of Rotation : %.2f" %yGyroDPS)
print ("Z-Axis of Rotation : %.2f" %zGyroDPS)
n += 1
How can I determine the "dt" from the cmplementary filter equation?
    \$\begingroup\$ #define dt 0.01 // 10 ms sample rate! \$\endgroup\$ – Sunnyskyguy EE75 May 5 at 15:36
  • \$\begingroup\$ I do not understand why the author get to set the dt as 0.1 . \$\endgroup\$ – ckkkk May 5 at 15:40
  • \$\begingroup\$ where? ......... \$\endgroup\$ – Sunnyskyguy EE75 May 5 at 16:04
  • \$\begingroup\$ dt is just the time between two calls of the routine you posted. There should be a TIMER or alike in your code doing so at a rate of your choice. \$\endgroup\$ – carloc May 5 at 16:17
  • \$\begingroup\$ Wait, now i know what dt means. But this i do not quite understand. "There should be a TIMER or alike in your code doing so at a rate of your choice" \$\endgroup\$ – ckkkk May 6 at 11:44
\$dt\$ in that expression is the time step. So if you're sampling at 100Hz, \$dt = 10\mathrm{ms}\$, if you're sampling at 500Hz, \$dt = 2\mathrm{ms}\$, etc.
  • \$\begingroup\$ But, how can i know about the sampling rate? \$\endgroup\$ – ckkkk May 5 at 15:40
  • \$\begingroup\$ @ckkkk Read the datasheet? \$\endgroup\$ – Long Pham May 5 at 15:47
  • \$\begingroup\$ I meant how do i know if the sensor actually really did output that much of data? \$\endgroup\$ – ckkkk May 6 at 11:39
  • \$\begingroup\$ That's entirely a separate problem, and way too complicated to answer as a comment in something unrelated. If you're concerned, ask it separately. The bottom line, though, is that you check to make sure. \$\endgroup\$ – TimWescott May 6 at 15:14
  • \$\begingroup\$ Yea, by default its 100Hz so i am good, so i should just follow the author and set the dt to 0.01? \$\endgroup\$ – ckkkk May 7 at 16:39
Its the period (in ms) of your filter routine.
  • \$\begingroup\$ Means how many sensor data i can get? \$\endgroup\$ – ckkkk May 5 at 15:40
  • \$\begingroup\$ No, it means a time difference between two last new values. In your example, the time between two readings from sensor. \$\endgroup\$ – Michal Podmanický May 5 at 15:52
  • \$\begingroup\$ Oh its like how many ms required for 1 data reading \$\endgroup\$ – ckkkk May 6 at 11:42
