I'm picking up a weird bug with my 74HC595 Shift Register's latch pin (Datasheet).
What do I want to do?
I'm essentially trying to visualise the shifting of the bits with the clock constantly running, and varying the serial input. I want to connect a LED to each output pin, and then connect my input clock (555 timer) to the latching pin (RCLK) and serial clock (SRCLK). As far as I understand the output LEDs should then show the state of the shift register, but delayed by one clock cycle, as mentioned in this datasheet:
If both clocks are connected together the input shift register is always one clock cycle ahead of the output register.
What is not working?
Connected the clocks together makes the shifting stop. Nothing shifts through. Not even in the shift registers, as I connected a LED to QH', and it never lights up.
The funny thing is that I could get it to work by unplugging the RCLKpin and letting it float. Then everything works perfectly, and I see my LEDs shifting. This is strange, as a change of state for RCLK is required for latching.
It even works if I place a switch on RCLK. Then I can see the latching only happening at the up and downward edges, as I expect.
But with the RCLKfloating shows the shifting bits perfectly.
My question:
  • Am I understanding how the 74HC595 chip works correctly? Is this intended behaviour?
  • Does the two input clocks need to be out of phase, as in the timing diagrams?
  • Could it just be EMI? It's built on a breadboard, but I put decoupling caps everywhere. Also, the speed I use never more than 2Hz, so I can't imagine that being the problem.
My setup:
My circuit is built on a breadboard, with the following schematic:
  • \$\begingroup\$ study the diagram on the first page of this ti.com/lit/ds/symlink/sn74hc595.pdf \$\endgroup\$
    – jsotola
    May 5, 2019 at 20:06
  • \$\begingroup\$ Thanks @jsotola, but I already have a few times. It shows there that the Qnoutputs only show what the storage register stores. And the storage register can only receive new values if the clock RCLK has an upward flank. So, leaving 'RCLK' floating should not update 'Qn'. :) \$\endgroup\$ May 5, 2019 at 20:11
  • \$\begingroup\$ Data from the serial shift register is placed in the output register with a rising pulse on the RCLK pin. \$\endgroup\$
    – G36
    May 5, 2019 at 20:12
  • \$\begingroup\$ Thanks @G36, but I am aware of that fact. That is why I'm confused why my circuit doesn't work if I connect both clocks together, and hence my question. \$\endgroup\$ May 5, 2019 at 20:13
    \$\begingroup\$ Are you sure there is only one clock driving both RCLK and SRCLK? From where does the clock come from? Also, this is a CMOS chip, inputs must not be left floating, or they will act funnily. The floating input might receive mains frequency hum and trigger to that. \$\endgroup\$
    – Justme
    May 5, 2019 at 20:21
Short answer
A wild guess: did you remember to add a 0.1uf capacitor between Vcc and GND, as the 74HC595 datasheet suggests? This makes a huge difference.
Long answer
I just tried something that has a lot in common with what you were doing in your experiment. Here's my configuration
  1. I clock my 74HC595 from a 555 timer operating at 1.5 Hz with 50% duty cycle. I.e. nice even square pulses of fairly low frequency.
  2. The clock is fed into RCLK and SRCLK shorted together. According to the TI datasheet this a valid mode of operation for 74HC595. It says that in this configuration "the shift register is one clock pulse ahead of the storage register". Fine with me.
  3. The SER input is normally pulled down, but can be pulled up by a button. The longer I keep the button depressed, the more 1s is fed into the register as the clock ticks.
  4. No input is left floating: everything is either tied to GND or to Vcc.
  5. The outputs are connected to 8 LEDs with 470 Ohm resistors in series.
  6. The whole assembly is powered by 5V from a regulated PSU.
In this configuration I observed a rather strange behavior.
When I attempted to feed in a single 1 bit (by holding the button down for a fairly short period of time) I got the following sequence of combinations from my diodes, per each clock cycle
There two strange things here. Firstly, somehow one bit has turned into two bits. (I monitored the clock and the input on an oscilloscope and I knew for sure that I only fed in one bit). Secondly, which is even more strange, each clock cycle the register gets shifted by 2 bits (!) instead on one.
In the next experiment I held the button down for a long time - to fill the entire register with 1s - and then released it. This is what I observed
***.....   <--- strange
********   <--- normal
.......*   <--- strange
You can already see the underlying logic behind this behavior: when the number of 1s in the register is low, the register behaves "crazily" and shifts by 2 bits each clock cycle. But once the number of stored 1s gets higher, it suddenly switches to perfectly normal behavior.
I was able to immediately confirm this: if I tried to hold down the button to create a train of 4 sequential 1s, that train shifted through the register in perfectly correct fashion: one bit per clock cycle. No problems whatsoever. Only low-1-bit count patterns made 74HC595 to glitch.
And then I took another look at the datasheet and noticed that I forgot this
The moment I added that capacitor all problems went away.
  • \$\begingroup\$ I guess I have this problem too, however I wondered: can I also use a bigger capacitor if I don't have a exact 0.1uf capacitor laying around, or does it due to some specific reasons need exactly 0.1uf? \$\endgroup\$ Feb 18, 2022 at 21:40
Although I don't think a can give a full answer to the whole question, just my 2c. I ran into the same issue last weekend, namely sn74hc595n not doing anything if connecting clocks together.
First of all, leaving an input floating is not good. All datasheets say no input must be floating.
As to why your (and mine) 74hc595 did not work with the clocks connected together (even though the datasheet seems to imply it's fine), my current theory is that by connecting the clocks together we're potentially violating the timing requirement regarding SRCLK↑ before RCLK↑: according to the datasheet, it's required that if SRCLK rising edge precedes a RCLK rising edge, SRCLK should not come within 19ns (at 4.5V VCC) of RCLK. By raising both clock signals at the same time, they'll be within 19ns from each other, which breaks the requirement. Granted, if this is true then the datasheet is wrong in implying the clocks can be connected together (or maybe it means something different...). I've found other datasheets (like this toshiba 74hc595) which do not say the clocks can be connected together. So at this point, I'm doubting the accuracy of the TI datasheet. I haven't been able to confirm or rule out this.
  • \$\begingroup\$ Nice first contribution, although I don't think it is a timing issue in this case. Most likely, the 555 is not outputting valid CMOS logic levels. \$\endgroup\$ Oct 8, 2019 at 17:17
  • \$\begingroup\$ Yeah I'm not really sure either. But for what it's worth, I was running into the similar issues while driving the clocks from an arduino pin. \$\endgroup\$ Oct 8, 2019 at 17:20
  • \$\begingroup\$ Also my 74hc595 is a 10c a piece ic from AliExpress, so maybe it's not even original... \$\endgroup\$ Oct 8, 2019 at 17:23
  • \$\begingroup\$ That could be a problem. An Arduino should have no trouble driving the inputs of a '595, but decoupling can be an issue. \$\endgroup\$ Oct 8, 2019 at 17:26
  • \$\begingroup\$ True. I was using a 1uf cap, that's what I had at home. I'll try with a 100nf if I can get ahold of one. Thanks for pointing that out. \$\endgroup\$ Oct 8, 2019 at 17:28
