I am making a motor and was wondering if it is necessary to use insulated copper wire instead of any regular copper wire.
    \$\begingroup\$ Thought experiment: rather than give you a direct answer, can you think of any reason why insulation might be required? \$\endgroup\$ – Transistor May 5 '19 at 23:27
  • \$\begingroup\$ @Transistor The OP would probably first need to understand why a motor works. The OP might not know the difference between electrons spreading out in any and all directions or being coerced to flow along certain lines. Thought experiments work if you know a few things. Otherwise, it's all just phlogiston. (Experienced and smart people spent centuries trying to figure out why their floating bridges sunk or their extra-large ships didn't scale up as expected and would sink. It takes "theory" to be able to see!) \$\endgroup\$ – jonk May 5 '19 at 23:46
  • \$\begingroup\$ You want all the electrons to take the long way around through all the coils, and not just take a short-cut across the coils. \$\endgroup\$ – brhans May 6 '19 at 0:21
  • \$\begingroup\$ If you did not use insulated wire, you would just use a split solid copper tube instead of having to wind anything, but then you would need to use a very low voltage supply capable of very high current instead of something more reasonable. \$\endgroup\$ – DKNguyen May 6 '19 at 0:24
This depends on what you mean by "insulated".
In a motor or any device that uses multiple turns to form an inductor - a device that increases the magnetic field by using a single isolated multi-turn conductor, then the current MUST flow into the wire at the input, travel through the length of the wire without any alternative paths available and exit at the other end.
  1. What you term "normal copper wire" is probably wire insulated with a thin conformal coating usually with a thickness in the 1-10 thorsandths of an inch. This may be polyurethane or some other 'plastic' and its thickness is normally small compared with the wire diameter.
  1. What you mean by insulated wire is probably wire with an outer coating of thick insulation - often PVC - with the insulated coating often coloured and able to be stripped from the wire, if desired, leaving bare uninsulated copper. The insulating coating may be 10% or more of the total wire diameter.
  1. Also available, and less common, is bare copper wire with NO insulating coat. It may not be visually obvious that such wire does NOT have a thin insulating coat - testing with an Ohm meter or manufacturer's specifications may be needed to be sure.
Both wire in 1. and 2. are potentially suited for constructing motors. The aim is to use a wire with as mechanically thin as coating as possible BUT having a voltage breakdown rating adequate for the task and adequate resistance to mechanical damage which could occur during manufacture and use.
Wire of type 2. with thick insulation is usually used for distribution and interconnection purposes, where resistance to mechanical stress is of great importance.
Wire of type 1. is normally used in motors where voltage resistance is paramount and mechanical issues are controlled when the wire is handled and wound and in the final product.
