I'd need to build a test fixture with very small pogo pins (1.27 mm spacing between the closest pins). I've seen fixtures before that use very long, very thin pogo pins almost exactly like this one in the drawing - 0.5mm diameter: pogo pin
Now the question: how the heck does one attach anything to the base of this? The base is just a round pin, no solder cup or anything, there is really nothing that a wire can attach to, and I don't think soldering to a PCB through hole is the usual approach either.
I've seen an array of these stuck through a piece of drilled fiberglass (I think just press-fit through) but I never saw what the electrical connections looked like underneath.
What's the usual approach to building test fixtures using these types of very small pins? How to connect electrically and how to hold them in place?
    \$\begingroup\$ PCBs (many times dual level) are often used ...or a nylon plate, Delrin, PTFE or simply HDPE plastics. Soldered wires are common, but PCBs are best allowing connection to be brought to connectors. \$\endgroup\$ May 6, 2019 at 5:12
Pogo pins are designed to be placed in pogo pin receptacles or sockets, slightly larger sleeves made of similar material.
Your P50 pogos would use an R50 socket, P75's would use an R75 and so on. Knowing that will drastically improve your chances of finding an online vendor.
Common socket forms have an indented rear to which fine wire can be soldered and covered with tiny heatshrink after the socket is pressed into a CNC drill hole in a carrier plate. You can also sometimes see them sold with wires already attached, which saves some fiddly handwork.
At least in the R75 size in addition to the solder form (such as R75-3S), you can get sockets ending in a square header pin (R75-2W) which you could wire wrap to, or possibly even use a socket jumper wire, or if you match a standard header IDC ribbon cable connector on.
In a pinch you can carefully solder to the pogo itself; the downside is that if it wears out, bends, or start sticking in use, you then have to replace the wiring too. In contrast, if sockets are used you just carefully extract the bad pogo with pliers and put in a new one.
  • \$\begingroup\$ Thanks, R50 sockets is just what I needed.Are those ever soldered into through holes? Which is better: solder these to a test fixture PCB or wire them point to point? \$\endgroup\$
    – Alex I
    May 8, 2019 at 7:36
