I want to configure ADC on STM32(Nucleo-F401RE) using Arduino IDE and transmit the values through SPI to Basys 3 FPGA(End Goal). The ADC works for input signal frequency only below 100Hz. How do I increase the throughput rate? My project requires conversion of analog signal between 500KHz to 900Khz.
 #include <f401reMap.h>
float analogPin = pinMap(31); //PA0
float val = 0;  // variable to store the value read
void setup() {
  Serial.begin(115200); //  setup serial
  analogReadResolution(12);
void loop() {
  val = analogRead(analogPin);  // read the input pin
  Serial.println(val);          // debug value
In the past,I have used Keil and STMCubeMX. It did not sample the input signal below 100Hz which was achievable using Arduino IDE. I have tried increasing the sampling cycles, the issue persists. Configured ADC without DMA with HAL_ADC_Start function and transferred the values to PC through UART,still unable to retrieve the original signal. I'm unable to isolate where the problem lies. What am I missing?
    \$\begingroup\$ Bias the ADC input, using a voltage divider with 2 resistors, each 10Kohm. Monitor the midpoint with a scope, AC coupled and 0.1 volt/division. You will see the ADC sampling events, as a quick drop in voltage and a slower recharge. What is the frequency of those events? is the timing consistent? \$\endgroup\$ – analogsystemsrf May 6 '19 at 9:56
You are hitting limits when Arduino IDE starts being "unfriendly" and it is in my opinion easier to use more "professional" IDE. Your current code has problem that you make 1 ADC conversion (with X default parameters) and then you send them through serial link to PC. This is slow, especially if you are using a lot of HAL drivers and standard functions with a lot of overhead.
For your project, if you want to achieve reliable ADC sample frequency you will need to use set up ADC yourself and transfer data to SPI via DMA. You can setup all of this in Arduino IDE but I think it can be done much more easily in other IDEs. You can find list of recommended IDEs on STM page about your board.
