Despite low-pass hardware filters on ADC inputs I am having a lot of erratic readings. There are 8 single-ended channels in DMA sequence and it is configured for cyclic sampling. Sampling time is set to maximum (601 cycles). The inputs connected to feedback resistors in actuators. Unfortunately, the power wires and feedback wires are in the same cable, without any shielding between them, so some noise is expected.
The results, however, are worse than expected - out of 4M samplings about 200K have more than 20 difference between consecutive readings, with maximum difference exceeding 2000 (on 4096 ADC range).
Now, my understanding is that "memory data size" in DMA configuration means it won't be changing one byte of the 16-bit conversion result while MCU is reading the other. Although it might simply be used for data re-packaging.
Just in case, I've replaced one target memory buffer with two and used half-transfer-complete/transfer-complete interrupts to make sure MCU is reading from one buffer while DMA is filling another. Did not make any difference.
The questions:
  • does "memory data size" safeguard from concurrent multi-byte memory access in any way?
  • if not, what else can I do to reduce noise? For example one trick on Atmel chips was to read and discard first ADC value, then read same channel again. I am not sure I can do this with cyclic configuration.
Note, that I am not asking for SW filtering methods. I have those prepared and tested many times before, and will use them in the final implementation anyway. What I am hoping for is some advice on reducing amount of spikes in the raw ADC output to begin with.
What's the output impedance of the thing you are measuring? The ADC has a mux followed by a switched cap. When measuring a high impedance source, the charge on the cap imparted from one channel can discharge in to another channel.
If you are not already doing this, place a buffer amp in between the micro-controller and each measurement source.
  • \$\begingroup\$ The inputs connected to wipers of 5k potentiometers powered by 3.3V. There are 1k+0.1uF low-pass filters between the wipers and inputs. To me this looks low enough, compared to 100k ADC input impedance. \$\endgroup\$
    – Maple
    May 7, 2019 at 2:19
  • \$\begingroup\$ One way you can tell is measure only one channel (preferably a noisy one) and see if the noise goes away. Seriously though, I'd look in to this, I've had issues with the sampling cap "transferring" measurements from one channel to another. \$\endgroup\$
    – pgvoorhees
    May 7, 2019 at 11:48
