I'm using the cryptoauthentiction lib from microship, and I'm trying to get a public key from it using the function in the code listing below.
atcab_get_pubkey https://github.com/ALLTERCO/mongoose-iot/blob/master/third_party/cryptoauthlib/test/atca_basic_tests.c
The function works only when I set a breakpoint in the debugger after it. If I don't set a breakpoint the code gets stuck and stalls.
The function uses I2C communication, and there is no acknowledgement received until I hit a breakpoint.
Any hints how to solve that issue ?
/* I2C3 init function */
static void MX_I2C3_Init(void)
  hi2c3.Instance = I2C3;
  hi2c3.Init.Timing = 0x10808DD3;
  hi2c3.Init.OwnAddress1 = 0;
  hi2c3.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
  hi2c3.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
  hi2c3.Init.OwnAddress2 = 0;
  hi2c3.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
  hi2c3.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
  hi2c3.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
  if (HAL_I2C_Init(&hi2c3) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
    /**Configure Analogue filter
  if (HAL_I2CEx_ConfigAnalogFilter(&hi2c3, I2C_ANALOGFILTER_ENABLE) != HAL_OK)
    /**Configure Digital filter
  if (HAL_I2CEx_ConfigDigitalFilter(&hi2c3, 0) != HAL_OK)
