-1
I am watching this video.
https://www.youtube.com/watch?v=vwJYIorz_Aw
at 1:05 it shows a diode as "blocking" current, even though there seems to be a return path through the diode and back to the battery via the capacitor or light bulb?
    \$\begingroup\$ That's the function of a diode. If you're wondering how one works--there are good questions on this site about that, I'm sure, since it's a pretty basic question. Diodes act like valves that only allow through current in one direction. \$\endgroup\$
    – Hearth
    May 9 '19 at 1:46
  • \$\begingroup\$ But the diode is pointing in the "correct" direction. \$\endgroup\$
    – user221241
    May 9 '19 at 1:47
  • \$\begingroup\$ Is it? What's the voltage on the anode, and what's the voltage on the cathode? \$\endgroup\$
    – Hearth
    May 9 '19 at 1:49
    \$\begingroup\$ @Juan Don't answer questions in the comment section. It even says explicitly when you open up the comment input field. \$\endgroup\$
    – pipe
    May 9 '19 at 11:43
    \$\begingroup\$ I'm VTC unclear because the whole question relies on third party information. I'll remove my vote if you include everything necessary to answer the question in the actual question. \$\endgroup\$
    – pipe
    May 9 '19 at 11:44
Figure 1. A diode is like a one-way valve in a water circuit. Source: What is an LED.
Diodes are electrical non-return valves. If you look at the check-valve in the figure above, it should be clear that the spring normally keeps the ball in position and prevents back-flow. When “forward-biased” the ball shut-off can be moved against the spring but it will take some initial pressure to move the ball. This results in a pressure drop across the valve: the pressure downstream will be less than the inlet pressure.
In a similar manner the PN junction causes a voltage drop. For silicon it is about 0.7 V. Since there is a PN junction in the base-emitter of your transistor you can expect a 0.7 V drop across it when forward biased.
I have written a little more on the topic of LEDs in the linked article but the principle is the same as LEDs are light-emitting diodes.
At 1:05 it shows a diode as "blocking" current, even though there seems to be a return path through the diode and back to the battery via the capacitor or light bulb?
This would be analogous to having a direct feed into the bottom of a water tank in your attic. You don't want it to drain back out when the water pressure drops so the addition of a non-return valve in the line - the diode - prevents this. Watch the video again and you'll see that the diode only conducts when forward biased.
It would be nice if you mention what is your knowledge in the electronics and physics. It all comes down to physics we are talking about the diode. There's something called potential barrier that plays the major role during the conduction of current through the diode. The potential barrier(measured in volts) is the minimum voltage required across the diode to conduct in the forward direction(direction the diode is pointing). Typically the value is 0.7V for silcon diode. This implies that the n-side of the diode is at 0.7V with respect to the p-side. So in order to conduct through the diode, the diode must have p-side at higher potential than the n-side. This is called forward biasing.When the diode is forward biased, the diode conducts current in the direction it(diode) is pointing to. This is the case for forward conduction through diode.
The case of reverse current flow is pretty interesting. The diode stops the flow of current in the opposite direction when the n-side is at higher potential then the p-side(Reversed Bias case). When there is reverse bias, the n-side is at "more higher potential" than the p-side. If you apply reverse biasing potential of 3V, the n-side is at 3.7V(for silicon diode)with respect to the p-side.
Its a nice way to explain something with graph. Here's a graph showing the V-I curve for a typical silicon diode
Increasing value of V in forward biasing implies incresing the potential of p-side. Once the p-side raeches 0.7V, the n-side and p-side are at same potential, so no any potential barrier now. Now, when the p-side's potentail is increased further, the diode is forward biased and allows significant current to flow through the diode.
In the reversed bias zone, note that the unit of current is in microAmps. When the reverse bias voltage is less than Vbr(Breakdown voltage), the current is few microamps which can be considered as "no conduction". Beyond the value of Vbr, there is whole new story again. The normal diode is not supposed to be operated at this value of reverse bias. But there are something called Zener diodes which are diodes but operating at reverse bias at value higher than Vbr.
Setting aside the topic of forward biasing a diode, at 1:05 in your video the input side of the diode (or, the anode) is connected to ground.
In an ideal circuit, when the switch is closed there is a direct 0 Ω connection to ground, which shorts out the rest of the circuit.
