Assume you have an intermediate input/outpout device connected to a coaxial line. For example, the device may be a DC-bloc, a bias tee, or simply a PCB microstrip transmission line.
Using a signal generator (e.g. YIG oscillators), you can generate a continuous wave and feed the input of the device.
At a given frequency, you have measured the power of the oscillator dissipated in the 50ohm input load of your spectrum analyzer (without connecting the device), and noted the value, e.g. P1 = 20dbm. Then you connect the device between the oscillator and the spectrum analyzer and measure again the power, say P2 = 15dbm.
I would like a mathematical relation between P1 and P2 and the reflection coefficient (or equivalently the VSWR) caused by the device. Is it possible ?
