I just broke my sewing machine (it's an old Viktoria machine about 30-40 years old) and now I am looking for a replacement safety capacitor. The one installed is a RIFA PME 271 M 547 paper capacitor.
I have looked online and found a replacement on ebay RIFA KONDENSATOR 275V~ SH 47n X2 PME271M 40/100/56/C or this one EVOX RIFA - PME271M547M - CAPACITOR, CLASS X2, 0.047UF.
My problem is, that the old Capacitor has a different number sequence.
Old Capacitor
It's a bit hard to see but it reads 40/065/56 while all capacitors I found had 40/100/56. I tried to find out the meaning of this values but could not find an answer.
Questions:
  • Is it ok to buy the capacitors I found?
  • What do these numbers mean?
Any answer is appreciated
I would not be replacing a failed RIFA cap with an Ebay example of the same part of unknown age.
These old parts are notorious for failing in a cloud of foul smelling smoke, generally 30+ years after being made, basically the housing cracks, moisture gets in and it all goes sideways.
The original is a 47nF 250V Class X2 cap.
Farnell have R463F247050N0K for less then your ebay part, that is coming from a proper distributor and will be of recent manufacture.
Basically the important things for a cap in this role are that it be class X2, and rated for at least 250V, capacitance is not that critical.
  • \$\begingroup\$ Thanks. Is there any benefit in buying the pme271m547. They are 3 times as expensive, but since I have to pay $6 for shipping to Germany I would not mind spending a bit more, if it helps. \$\endgroup\$
    – beronir
    May 9, 2019 at 16:02
The ‘new’ Evox Rifa are made by Kemet, but kept the Rifa brand name. Just because a eBay listing says Evox Rifa, don’t presume they are old stock. Rifa is a EU high quality made capacitor. They are pricey because of their quality. These capacitors can last well over 40 years.
Search for PME271M547 by Farnell or other supplier.
Ref: RIFA GPC PME271M547 0.047 µF fo=7.0 MHz 250V
It is quite easy to find.
If used for interference suppression could (verify before!) be replaced by 0.047 µF / 100 Ω 600V~
