This question already has an answer here:
Assuming I don't exceed the wattage rating of the whole system then why can't a piggy back let say ups to a surge suppressor in order to let say increase the protection of my system.
Let's assume: I have 1500va APS UPS that has built in surge suppressor and now I want to plug in a Tripp-Lite 6 outlet metal housed surge suppressor to single output of the battery side of the ups. Everything else is connected to the Tripp lite and nothing else besides the Tripp lite is connected to the ups. The total draw is let say 1500watts.
So what is negative about piggy backing surge suppressors?
Can I use the above setup without any detrimental effects.
marked as duplicate by JRE, Marcus Müller, Charles Cowie, winny, laptop2d May 9 at 18:54
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • \$\begingroup\$ Probably because they won't work as you think they will... \$\endgroup\$ – Solar Mike May 9 at 17:29
  • \$\begingroup\$ If surge protectors need current limiting. Will that work? Is it redundant? \$\endgroup\$ – Sunnyskyguy EE75 May 9 at 17:40
  • \$\begingroup\$ Because the fire warden won't let you \$\endgroup\$ – laptop2d May 9 at 18:54
