I am interfacing ADS1282 with LPC1768 through SPI. Currently I am not onnected analog supplies. Only digital supplies connected.I am trying to check whether communication is happening or not.But I can't read the register values.
These are the steps I followed.
1.sent 0x11 for - Stop continuous reading.
2.sent 0x20 for - Reading 1st register.
3.sent 0x00 for reading only on e register.
4.Dummy write 0x00 for reading data.
Given delay 100 microseconds in between instructions. I am getting only 0x00. I checked different registers. SCLK = 3 MHZ
  • \$\begingroup\$ Can you talk to the chip at all? \$\endgroup\$ May 10, 2019 at 12:42
  • \$\begingroup\$ blog.codinghorror.com/rubber-duck-problem-solving \$\endgroup\$ May 10, 2019 at 12:44
  • \$\begingroup\$ The wrong clock polarity might be a reason. Can you monitor communication with an oscilloscope/logic analyzer? It's likely to be more a configuration issue than a hardware problem. You could provide us with some code, but I guess it's the wrong board in that case. \$\endgroup\$
    – Sim Son
    May 10, 2019 at 16:38
The datasheet says the chip is internally held in reset until power supplies are valid. Do not partially power chips unless datasheet specifically allows this under some conditions.
