39
I have several different RGB LEDs and bicolour red/green LEDs, from different suppliers.
I find that, with the appropriate resistors, they can produce a perfect orange and cyan; and a barely acceptable magenta. One thing they cannot produce, however, is a tolerable yellow. It looks awful.
Given that our eyes see yellow simply as a combination of red and green; and given that TVs and computer monitors successfully render a lovely yellow on a daily basis using nothing more than red and green pixels; why is it that my LEDs are utterly incapable of the feat? I have tried googling for answers, and come up empty.
Of course, each colour will have its own forward voltage, but I have allowed for this by providing different resistances; or, in some cases, adjustable PWM signals. But no matter how I vary the amount of red vs. the amount of green, at no point is a decent yellow produced.
Sadly, due to the limitations of cameras, I am unable to provide a realistic illustration of the pathetic yellow they produce. But suffice it to say that it's a sickly, unpleasant colour.
Now, maybe I just have low quality LEDs. But still, any shade of yellow should be possible from the correct ratio of red and green. Even if the green is a bit red-shifted already, surely I would simply need less of it?
  • 6
    \$\begingroup\$ This will be much less opinionated and much more answerable if you could post datasheet to RGB and RG LEDs you have tried and seen. Personally I have seen RG LEDs that generates a pleasant yellow so I couldn't answer it. \$\endgroup\$
    – pipe
    May 10, 2019 at 13:30
    \$\begingroup\$ "Given that our eyes see yellow simply as a combination of red and green;" -- have you never seen a color chart? \$\endgroup\$ May 10, 2019 at 13:40
  • 4
    \$\begingroup\$ @pipe Try brown! When I'm not an EE, I do concerts and shows. Do you have gingerbread-mans during Christmas where you live? Have to tried to light a set in gingerbread-brown? I had normal halogen light and the full LEE color filter catalogue at my disposal, but good brown, never. \$\endgroup\$
    – winny
    May 10, 2019 at 15:59
    \$\begingroup\$ @pipe brown is nothing more than dark yellow-orange, but easier said than done. \$\endgroup\$
    – hobbs
    May 10, 2019 at 22:29
    \$\begingroup\$ @winny can an LED monitor produce brown without magic? \$\endgroup\$ May 10, 2019 at 22:40
60
Most probably because of short wavelength of your green LED and not as monochromatic green as you might expect (x and y coordinates closer to the center). If you take a look at the CIE 1931 curve and plot your red and green x and y coordinates (listed in the datasheet from serious manufacturers, otherwise assume the pure wavelength on the outer rim or move it in slightly), the only colors you are able to produce are along that line. For RGB, it's the same but you are forming a triangle instead and you can only mix color within that triangle.
Yellow is tricky here because you need your green to be almost yellow to be able to mix green and red to a good yellow, at which point you have sacrificed a lot of green and cyan colors. To make things worse, the production spread in green LEDs is very high compared to other colors, so it will vary unless you calibrate each one, at least from batch to batch.
Pardon my paint skills here, but let me give you three examples. A "yellow-optimized" RGB LED will have high wavelength for the green LED but you are missing out a large area of light blue, cyan and blue-green:
Yellow-optimized
A cyan-optimized RGB LED has short wavelength on the green LED and will sacrifice the yellow colors to get good cyan.
Cyan-optimized
Commercial RGBA (A for amber, thanks for pointing it out Ilmari Karonen) LEDs exists for this reason, at which point you will have a trapezium (thanks Wildcard!) with four points you can draw all the colors within, at the added expense of one more LED and associated driver channel.
RGBA
  • 8
    \$\begingroup\$ The color sensitivity of eyes also varies. The pigments (essentially filters) in the (usually) three cones are controlled by genes, and some people are far more sensitive to one primary color than the other two. Lighting spectra are based on average sensitivities, so some people see a particular color very differently. I see the red/green part of the spectrum slightly differently with each of my eyes, particularly around the yellow region. Whether that's due to a mechanical difference in my retina, or how I process the signals is unknown. en.wikipedia.org/wiki/Tetrachromacy#Humans \$\endgroup\$
    – Phil G
    May 10, 2019 at 16:31
  • 15
    \$\begingroup\$ For anyone else curious about it, in this context the A in RGBA apparently stands for "amber". (I was pretty sure it couldn't be "alpha", but I couldn't figure out what else it might stand for, so I had to Google it. Now you know.) \$\endgroup\$ May 10, 2019 at 17:14
  • 8
    \$\begingroup\$ I learned this as a side effect from researching why the green in some RGB LEDs required such a high voltage compared to the "normal" green LEDs. Turns out there are such things as "cyan optimized green" to get an arguably better coverage, and they have a different chemistry and thus a higher voltage drop. \$\endgroup\$
    – pipe
    May 10, 2019 at 17:53
  • 9
    \$\begingroup\$ @pipe To some extent, green LED does not exist in nature. You either need to push red AlGaInP to become green or blue InGaN to appear green by doping. I would suspect this is the reason to the wide production spread. \$\endgroup\$
    – winny
    May 10, 2019 at 18:01
    \$\begingroup\$ @SodAlmighty -- any LED you get from a decent distributor (whether in stupidly high amounts or mere onesies) will have a datasheet (it may not ship with the part, but it will definitely be available online via the distributor's website!) \$\endgroup\$ May 11, 2019 at 3:25
19
It's even a little worse than winny indicates:
Green LEDs are finicky. One result is that green LEDs emit over a broader distribution of wavelengths instead of being a nearly laser-like single wavelength. And when you map that range of greens to the xy colorspace you're not on the spectral locus anymore. So even your yellow-optimized RGB LED may not get as close to the yellow as you'd hope.
From What is red? On the chromaticity of orange-red InGaN/GaN based LEDs: Achievable InGaN colors
For those who keep noting their LED monitors can show a nice yellow, your LED monitor almost certainly doesn't use three colors of LEDs. It instead is going to use white LEDs and color filters, and the white LEDs get their yellow from a phosphor instead of the bandgap of the semiconductor.
  • \$\begingroup\$ My slightly in “otherwise assume the pure wavelength on the outer rim or move it in slightly” may have been an understatement. Nice answer! \$\endgroup\$
    – winny
    May 11, 2019 at 7:27
  • \$\begingroup\$ OLED displays do use direct emissivity, do they have a closer to monochromatic green than normal LEDs? \$\endgroup\$ May 11, 2019 at 16:40
  • \$\begingroup\$ I'm afraid I don't know very much about OLEDs. In a quick web search I can only find one mention of the spectrum of an OLED, so don't take too much from this, but it looks like they may be similar. (And to be preemptive, I don't know much about quantum dots either, but those are another way to get a color different, and possibly more specific, than the underlying emitter.) \$\endgroup\$
    – IceGlasses
    May 11, 2019 at 23:38
