This is a diagram for a flashing relay. Normally used for automotive, I'm curious if I can get it to work for my needs.
I want to be able to start and continue the flasher with a 12 V output, and while that output is on, flash a light bulb with a separate 12 V supply.
Is that possible with this type of relay?
So far as I can tell this flasher must be powered from the same supply that runs the lamps.
if you want to use a different supply for the lamps you couls have the flasher operate a relay use the relay to switch the lamp circuit,
  • \$\begingroup\$ Thanks for the input. I wanted to avoid using a 2nd relay if I could. I can easily use a 2 pin flasher to drive another single pole relay if it's really necessary. \$\endgroup\$
    – brett s
    May 11, 2019 at 2:25
  • \$\begingroup\$ You need to operate it within its normal load rating or it should go to 2X its flashing rate as it is in fault mode. \$\endgroup\$
    – Gil
    May 10, 2022 at 0:50
