All units are in the SI
I'm doing my task from vacuum electronics - for the given klystron with a toroidal resonator[ug]
Resonator:
I have to find the $h$ parameter, that will satisfy given conditions:
$$f=10GHz$$
$$U_{resonator}=250V$$
$$electrons\space stream\space diameter\space 2a=6 mm=0,006 m$$
that can be found from the given toroidal resonator eigenfrequency formula, considering, $$b=2a$$ and \$c\$, as far, as I understand equals \$0,73\$: $$f_{\text{res}}=\frac{c}{\pi a \sqrt{\frac{2 h}{d} \ln \frac{b}{a}}}$$
\$d\$ can be found from the next equation, considering \$\theta=0,75\pi\$
$$\theta_{i}=\omega \tau=2 \pi f\left(d / v_{0}\right) \quad v_{0}=5,93 \times 10^{5} \sqrt{U_{\text{res}}}=9376153,262\space mps$$
When I put all this stuff in one, I got
$$d=v_0\dfrac{0,75\pi}{2\pi f}=\dfrac{0,75*3,14*9376153,262 }{2*3,14*10000000000}=0,000351606\space m$$ that seems correct
$$h=\dfrac{\dfrac{d(\dfrac{c}{f\pi 0,003})^2}{ln2}}{2}=\dfrac{\dfrac{0,000351606(\dfrac{0,73}{10000000000*3,14*0,003})^2}{ln2}}{2}=1,5*10^{-20}\space m$$ that is obviously wrong
If I put \$d\$ and \$h\$ in $$f_{\text{res}}=\frac{c}{\pi a \sqrt{\frac{2 h}{d} \ln \frac{b}{a}}}$$, I get 10000000000, that means, that I've calculated everything correctly.
I've been checking all steps, all formulas, maybe I had missed something, but no, seems that the problem is in resonator frequency formula - it's wrong. I've tried to find it in the internet but get failed.
Please, provide a specified toroidal resonator frequency formula, or, if the formula, given in my task correct, point me, where am I wrong.
enter image description here I got the next solution of my issue
