I'm trying to remind myself how to implement given function or karnaugh map with NAND or NOR gates. I remember how DeMorgan's laws work.
Let's say I have some Karnaugh Map and I want to implement the obtained function only with NAND gates.
To be efficient: should I group together zero's or one's? (Should I obtain PoS or SoP form of function to get to my result as fast as possible with least number of boolean algebra transformations?)
And same for NOR gates: should I group zero's or one's?
I understand that it all depends, but let's say that the Karnaugh Map is uniformly distributed with 0-s and 1-s and it is equally difficult (or easy) to group either.
Use the Karnaugh map to create an implementation that uses NOT, OR, and AND gates.
Then, recognize that you can wire a NAND or NOR so you get a NOT function. Use DeMorgan's theory to get an OR function from a NAND or to get an AND function from a NOR. Replace all of the NOT, OR, and AND gates in your circuit with these equivalents.
That should get you pretty far. Come back if you have more specific questions.
