What are the advantages/disadvantages of compensated and uncompensated op amps?
Thank you in advance.
closed as too broad by winny, Colin, Leon Heller, Bimpelrekkie, Chupacabras May 13 at 10:14
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Examine the datasheet for the UA709 operational amplifier. There are numerous compensation options, and the ability to adjust the poles is key to achieving precision gain at high frequencies. For example, gain of 60dB closed loop, out to 200KHz. Design and Datasheet are by Bob Widlar. \$\endgroup\$ – analogsystemsrf May 13 at 12:54
If you have to ask, then you shouldn't use an uncompensated one.
Uncompensated will give you a higher slew rate and more bandwidth than the equivalent compensated op-amp, but you'll have to know what you're doing to make it stable, you can't just fling it like you do with a compensated one.
